Dennis Pataki | 06/08/2023 21:31:12 |
16 forum posts | I repair old condensate and vacuum pumps, primarily those used for old steam plants for building heating. Many of these old pumps use old style packing box type shaft seals. Many times the packing box bores in the cast iron housings develop a corrosion build up that prevent the compression gland from entering the bore to compress the packing rings. As part of my repair work, I have to clean out this build up so the compression gland will enter this bore. So far, I've been using abrasive flap wheels in a high speed die grinder and this will usually get the job done in a good enough sort of way, but not always. I'd really like to come up with a hand rotated cutting tool for this job, but need some guidance as to how it might be constructed. Case in point, a 2.137" packing box bore that is approximately 3" deep. I'm hoping to find a small tool and cutter grinding shop that could make a hand reamer to this dimension, but no luck with that idea so far. My dream solution would be a vertical milling machine with boring tool in an adjustable boring head. Problem is, I just don't have room for even a small vertical mill. Other problem is, sometimes I have to do this work at a job site where a vertical mill is not available. |
Pete. | 07/08/2023 01:04:21 |
![]() 910 forum posts 303 photos | Sounds like an expanding hand reamer is what you're looking for, not particularly expensive at that size, buy a decent one if you're using it for work not hobby. |
Pete. | 07/08/2023 01:16:11 |
![]() 910 forum posts 303 photos | A H16 sounds about the size you're looking for. |
Speedy Builder5 | 07/08/2023 06:50:53 |
2878 forum posts 248 photos | Cylinder hone - This sort of thing ?? - Available almost everywhere |
noel shelley | 07/08/2023 09:39:01 |
2308 forum posts 33 photos | Though of fixed size a rotabroach the right size would work or as speedy says a cylinder hone. Noel. |
Nicholas Farr | 07/08/2023 10:02:26 |
![]() 3988 forum posts 1799 photos | Hi, i agree with using a cylinder hone, with an adjustable reamer, the blades wouldn't get to the bottom of a stuffing box. Regards Nick. |
peak4 | 07/08/2023 12:45:24 |
![]() 2207 forum posts 210 photos | I wonder if a David Brown type floating reamer would work, or whether having just the two flutes would allow chatter. |
Dennis Pataki | 07/08/2023 15:23:05 |
16 forum posts | Thanks all. Lots of good ideas here to consider. For the example cited, the bottom of the stuffing box bore has a shaft sleeve hole of slightly more than 1.5", so the expanding adjustable hand reamer may be worth a try. In any event, while it would be nice to clean out the entire stuffing box bore, what is really needed is to clean out the first 1/2" of depth so the compression gland will enter freely. Thanks again. |
old mart | 07/08/2023 15:51:38 |
4655 forum posts 304 photos | You can get adjustable reamers designed to go in blind holes, but they have much less range of movement, so you would have to get them very close to the size required. They commonly have brazed on carbide blades so they will stay sharp longer. |
HOWARDT | 07/08/2023 15:52:24 |
1081 forum posts 39 photos | I would consider a three bladed tool body with adjustable blades running lengthwise. The blades could made from some M2 HSS parting off blades and clamped into the body. Having three blades allows for jacking screws behind the blades. Used with a range of setting rings this would give a reasonably cheap tool. The tool could be fitted with adaptors to fit what ever you wanted to use to rotate it. |
peak4 | 07/08/2023 15:56:03 |
![]() 2207 forum posts 210 photos | Another possibility, just for cleaning the outer part, would be to do a search on "Cylinder Ridge Reamer"; sometimes adding "Vintage" helps to find images of older designs which might be more appropriate, or easier to modify to a shallower bore. |
Nicholas Farr | 07/08/2023 16:40:07 |
![]() 3988 forum posts 1799 photos | Posted by Dennis Pataki on 07/08/2023 15:23:05:
Thanks all. Lots of good ideas here to consider. For the example cited, the bottom of the stuffing box bore has a shaft sleeve hole of slightly more than 1.5", so the expanding adjustable hand reamer may be worth a try. In any event, while it would be nice to clean out the entire stuffing box bore, what is really needed is to clean out the first 1/2" of depth so the compression gland will enter freely. Thanks again. Hi, Dennis, before you rush out and buy an adjustable reamer, which are not exactly cheap at the size you will need, I have a 1-13/16" to 2-7/32" one, and the bottom adjusting collar is just a shade over 1-3/4" in diameter and a little over 1" long, and the screw threaded portion is 1-1/2" in diameter. Of course there is a very slight taper towards the bottom end of the blades. Regards Nick. Edited By Nicholas Farr on 07/08/2023 16:49:13 |
