Here is a list of all the postings larry phelan 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: New member from Ireland |
03/05/2021 08:13:21 |
Correct, there is little or no machinery to be had here. |
Thread: Quick change tool post and parting tool for a lathe |
28/04/2021 18:59:46 |
Never managed to aquire a GCTP over the last 20 years, must be missing out on something ? |
Thread: Parting off 25mm copper |
26/04/2021 09:57:16 |
Dont see any mention of a tube there, I assumed it was a solid bar. |
Thread: JD Metals |
25/04/2021 15:51:35 |
Point taken ! It,s just that some of these posts seem to crop up out of the blue. No offence intended. |
25/04/2021 14:57:52 |
Leave them alone until they get their act together, they may need you more than you need them. |
Thread: B&D workmate |
25/04/2021 14:50:45 |
I have several of these benches, one of them a Workmate, the others are clones [Chinese junk ] which are easier to open and fold up and just as good in every way. I bought them for 15 Euro in Aldi,s years back and am still using them. Not much to go wrong with them, and easy to fix if required No way would I pay mad money for a B&D model, they are good, but not THAT good. They all do the job. I often have to use them to set up a bench to do something because my "Real" bench is cluttered up with junk. Am I alone ?? |
Thread: Drilled Hole Tolerances |
24/04/2021 16:25:57 |
Takes me all my time to try and sharpen them, never mind about the "finer" points. Anyone else in this club ? Dont be shy " |
Thread: End Mills and coatings |
24/04/2021 07:57:59 |
What,s that old saying about the workman blaming his tools--------------------? I have no coated end mills of any kind and I machine mostly BMS. Dont have any real problems with them and they are cheap enough to replace. Any time I did/do have a cock-up, it,s my doing, not the cutter. |
Thread: What to do when you lose something |
22/04/2021 14:03:42 |
Welcome to the club ! |
Thread: Plumbing Overflow - Help! |
19/04/2021 18:41:16 |
Dave, when dealing with house repairs, old or new, the first thing you need to learn is that there is no such thing as a "Handy" job. That 5 minute job usually turns into a 3hour one and still might not turn out right. How do I know ? Dont even ask ! Best thing to do, is to make a total mess of the first job, then you will not be asked to do any more ! Hope this helps. |
Thread: Trademark Infringements |
17/04/2021 10:01:15 |
Life can be so hard at times !! |
Thread: Drunken pulley |
15/04/2021 14:33:09 |
That would drive me nuts ! even looking at it. I would bore it out and fit a sleeve to be bored [not drilled ] to the correct size. Not that big a job and at least, you know it,s right |
Thread: Swarf: |
15/04/2021 14:27:25 |
I am the local producer of swarf, in fact that,s all I seem to produce. I bet there are many more like me, not too far away from you. Try your local recycle centre, that,s where I get rid of mine. |
Thread: Kuroda Boring & Facing head |
15/04/2021 09:12:26 |
Dont have one of those units myself, but if I did ,John,s input would sure help to sort things out ! Well done John, nice to know that there are people like you around ! |
Thread: Problem with 4 jaw chuck |
14/04/2021 12:24:45 |
4 jaw independent chuck, or self centring chuck ? |
Thread: Loctite or Draper? Much difference? |
12/04/2021 13:09:31 |
EGA Business is business, my boy ! What they dont know wont bother them. |
Thread: Laptop with a SD card slot |
12/04/2021 12:53:39 |
Welcome to the brave new world of laptops ! I found the same thing when I had to replace mine. When I asked about the slot for playing discs, they looked at me as if I had asked for a piece of moon rock. They then explained, as if talking to a half wit, that "these things" are old hat. Such kind words ! I used to burn discs on my old unit, but I have no idea how this could be done on my present laptop. Sad to say, due to the current "lockdown", I cannot even call on the services of the local 6 year old consultant. Life is not simple. |
Thread: Bandsaw - wood and metal ? |
11/04/2021 16:22:48 |
I have a Startright upright bandsaw for wood cutting [was never happy with it, even for that ], tried cutting light sheet steel with it, learned very quickly that it did not like it and it was rather scary. Speed is much too fast and material too difficult to control, and this was even with a suitable blade. Horses for courses, I think. As regards cutting 5" round anything, you are a brave man ! |
Thread: Face Knurling... |
11/04/2021 16:11:11 |
Jason, you do have a simple answer to most things ! Never needed to do this, but who knows ??? Thanks for the tip. |
Thread: Bending brass - hot, warm or cold? |
07/04/2021 09:55:02 |
One of my jobs in a past life was to bend 1/4" round brass bar to 90deg. I heated it to red heat, let it cool then bent it. |
