Member postings for Oldiron
Here is a list of all the postings Oldiron has made in our forums. Click on a thread name to jump to the thread.
Thread: Making metal flowers
14/01/2021 10:56:02
Posted by br on 14/01/2021 10:30:02:
Posted by Steviegtr on 03/01/2020 00:32:08:
20191206_200228.jpg20191206_190647.jpg20191206_174708.jpgMaking flowers from metal. I pulled out the old chimney back boiler & thick walled copper tubing. Rather than throw the tubing away I made use of it making this. Aslso one in alloy. Next is one in brass, the sheet has just arrived. Brass is harder to work so may take longer. The stems have yet to be made & the buds.
Click on the jpg above - get following message ?
Page Not Found
The page you requested cannot be found.
Click here to go to the homepage
br
I have same problem. regards
Thread: Myford ML10 main screw skating
13/01/2021 11:32:01
I'm here MichaelG. smiley I agree, 2 new gears needed.
regards
Thread: Mini lathe feed
13/01/2021 11:17:52
I do not have a mini lathe. It looks like the half nut is either stripped or is not engaging with the lead screw. Are there a lot of chips in the halfnut stopping it engaging?. Only stripping out the apron will give the correct answer.
regards
Thread: Wooden Gears
12/01/2021 10:46:04
Posted by Georgineer on 23/08/2020 11:53:48:
Posted by Tim Stevens on 22/08/2020 16:43:16:
An alternative gear-tooth cutting method, if you can access the kit, would be to draw out the gears in a CAD program and get them laser cut. This method uses a hot beam of light across the gear, so there should be no tendency to tear at the grain.
I think there are adverts in MEW for this sort of service.
Cheers, Tim
My personal objection to this would be an aesthetic one, because the cut surfaces are scorched black.
George B.
Edited By Georgineer on 23/08/2020 11:54:05
When we were kids did we not scorch the ends of our arrows black to make them harder ?
regards
Thread: Myford ml7 about to buy
12/01/2021 10:40:16
Hi Simon welcome to the forum. There are many many post on this subject. >>> Buying a lathe.
regards
Thread: 'jerryrigeverything'
11/01/2021 15:07:59
It is a good channel. No big hype, just get on with life. Love his wifes attitude to life.
regards
Thread: The Repair Shop is getting to me...
11/01/2021 11:11:03
Posted by not done it yet on 11/01/2021 10:33:15:
Posted by bricky on 10/01/2021 11:14:42:
I got a block of steel 6'*6'*6" from the tip but had to pay the operator 10 pounds to sneak it into my boot without the foreman noticing.
Bricky,
Are you sure?
3.7 tonnes into your boot? Let alone in one piece! Sell it for scrap and make a HUGE profit!
Even if you got your feet and inches swapped around, that is still over 300kg!
6" square block mild steel. Approx 58lb /26Kg not 300Kg. regards
Thread: Sensitive drill
10/01/2021 13:57:34
I have a 2hp mill and have used 1mm drill bits on that. Never snapped one off so it must be pretty sensitive. smileydevil
regards
10/01/2021 11:33:13
Posted by Bob Stevenson on 09/01/2021 15:44:12:
All the 'clockies' in my horology club are quite irritated by 'Repair Shop' now as they have to fend off friends and neighbours who have watched the sob stories and suddenly remember their own sob stories in relation to that clock in the loft that has not ticked in several decades but which they can't get rid of...... My own approach to neighbour women with the Smiths "last link with my Grandparents, but I don't have money for repairs" request is to explain that taking it apart will be the work of several hours!....When they finally ask; "what should I do with it" I usually say "Oh just drop it in the dust bin"......
I do really enjoy YouTube now!...does anyone look at 'jerryrigeverything'?
Yes I watch jerryrigeverything now and then. Now that is a story of love & determination. regards
Thread: ME Beam Engine valves
09/01/2021 14:13:15
Hi this looks like a duplicate post. Could be a bit of a PITA. Might be best to take one down.
regards
Thread: New, old Myford Super 7 essentials
07/01/2021 17:47:03
Posted by Giovanni Conte on 06/01/2021 14:19:56:
Guys good afternoon I am brand new to the group and would like a little help. Some time ago I bought a Myford super 7 B with natural and imperial gearbox and I read and downloaded some tables where by mounting a 33 or 34 tooth gear you can make metric threads. Therefore the gear must be mounted under the gear change gears (idle). On my Torino there is a double and fixed gear 12/30 teeth. how can i mount 33 or 34 teeth? If I remove the double do I have to keep 30 teeth internally and then mount 33 or 34 or is there something I'm missing? thank you for your future cooperation and thank you in advance. How can I understand how to send photos I am sending you some pictures of my jewels. Super 7B and ml7. greetings Giovanni
Hi Giovanni. Welcome to the forum. Sorry I do not have a Myford so cannot be of much help. It would be better to start a new thread so answers can be posted to it so as not to confuse the original posters query.
regards
Thread: What air compressor should I buy?
06/01/2021 18:13:51
I would personally go for all pushin fittings & plastic tube. So much easier to use as long as the tube is cut square. John Guest, Parker Legris or Aignip are available every where. If you have no local supplier and want to buy online with out using Ebay try here >> Hose & Hydraulics
UK supplier in East Midlands. Huge selection & 99.9% from stock.
regards
Thread: DTI Stand - Single Lock Type?
06/01/2021 17:41:49
I have a Noga and 2 cheap versions. The Noga is perfect as it should be for the price. The 2 cheaper items now work very well after stripping and fettling them.
regards
Thread: Re-grinding 2 MT Socket
04/01/2021 17:35:10
I am with Howard on this one. Use an 2MT drill shank to massage the bumps out.
Highly unlikely that the damage is so bad that a good lapping will not bring it back to usable condition.
regards
Thread: Removing soft solder from brass before silver soldering
03/01/2021 12:08:41
IanT 01/01/21 " and I'm afraid my tubes of Super Glue don't seem to have a great shelf-life once opened (I'm probably using the wrong kind?). "
Hi Ian. I find that keeping the super glue in the fridge door behind the wifes pickle pots seem to make it last a very long time. Just allow it to warm up a bit before use then straight back in the fridge.
regards
Thread: In anticipation of the New Year ...
03/01/2021 11:41:01
Graham Stoppani 03/01/21 "1. A laser based quantum computer has completed a calculation in 4 minutes. Doesn't sound much until you compare it to the time a traditional computer would have taken of 2.56 billion years."
I wonder how long it took to work out how long a traditional computer would take to do the calc' ?
Hides behind the settee. wink regards
Thread: PAT - Portable Appliance Test
31/12/2020 15:43:14
Yes it could. Over the years I have seen PC's, Monitors, Electronic calculators and £25000 robotic reciprocating powder coating arm that would not run after a PAT test. Difficult to prove that it was the test that killed them though.
I presume that the washer is in an indusrtial setting as home appliances are not liable to be PAT tested
Take your board to a local TV/PC repair shop, they may be able to change the duff component much cheaper that a replacement.
Best thing to do to stop it happening again is to wire the item direct to an outlet. ( no plug) It is then not liable for a PAT test.
regards
Thread: Myford ML7 Cross Slide adjustment
31/12/2020 15:28:27
You could at a pinch straighten the feedscrew. Remove it and hold the threads in a vise use some protection for the thread. Put a close fiting pipe over the bent end and pull gently on the pipe to straighten out the bend. With a bit of judicial force you should get a decent result. Make sure that the bend is close to the vise and dont try to yank the bend out be slow & carefull. Slowly slowly catchee monkey.
Good luck. regards
Thread: 2021
31/12/2020 15:13:31
All best wishes for a healthier happier new year to one and all.
regards
Thread: Tool identification help please..
30/12/2020 15:05:24
Paulimot has them in Germany. Should be available by post CK3
May be other suppliers around.
regards
