Member postings for Michael Bird 1
Here is a list of all the postings Michael Bird 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Interests other than Model Engineering
04/12/2018 12:03:07
1. Photography (birds,butterflies, dragonflies)
2. Bird watching
3. Genealogy
4. Astronomy
Thread: Myford ML7 not running true and spirals
16/10/2018 09:08:29
When I had spirals it turned out to be the headstock bearing caps were loose on my ML7. I tighten them up and the spirals went away.
Thread: Can anyone identify this vice please
29/06/2018 17:17:01
Thanks Vic it looks like the company, I will investigate further.
Amazing you found this.
29/06/2018 16:10:53
Can anyone identify this vice please. I cannot find any info on it at all, not even a website that mentions it.
It has a logo of a vice in red with the name "Allen" above it. The jaws measure 6".
Thread: D shaft inserts where to find them?
12/09/2017 07:24:12
Thanks Jeff I'll have a look into these later.
10/09/2017 21:23:31
The shaft is from a encoder, take a look at the link to see what I'm talking about.
The shaft turns extremely slow so plastic or brass would be OK. If no inserts are available I'll most likely drill and tap for grubscrew.
Thanks for the ideas guys.
10/09/2017 18:50:35
I need to place a 6mm "D Shaft" into the end of a stainless steel shaft. I don't have any equiment to broach a 6mm D hole and I don't really want to drill a normal hole and secure the flat with a grub screw.
Are there such things as plastic or brass "D" inserts that can be pushed or glued into a normal drilled hole.
I've googled this and can only find ready made knobs which I could break up and retrieve the inserts.
Thanks guys
Thread: Does anyone know what this is?
05/04/2017 17:36:07
I have a Sharp universal Milling Machine and it looks pretty similar.
Thread: Small Milling machine
24/03/2017 16:22:45
If you can find one the Sharp Mk2 Universal Milling Machine is a good machine.
Thread: Introducing...
26/02/2017 22:03:59
Hello Robert welcome to MEW.
I have a ML7 which is older then me as well, mine was made in 1948 so pretty old.
Thread: Just found a Binks Bullows Hydrovane compressor need help.
26/02/2017 13:11:42
The dial on the compressor goes up to 50 psi so 45 psi sounds about right.
25/02/2017 19:24:32
Thanks guys for your input.
John I'll post some pics on monday.
Brian I had a look at findmanual.net but couldn't find anything.
KWIL I'm not sure of what mark mine is but it has the serial number A15833. Just wanted to know if anyone runs their model engines with this compressor. Also where I could get copies of manuals, parts diagrams etc.
25/02/2017 16:33:08
I have managed to buy a very cheap compressor at as local auction. It's a Binks Bullows Hydrovane PR303E.
I have tried to google any info and to be honest there's hardly anything out there. It needs rewiring as it was sold as having a lead problem but that shouldn't be much of a problem.
I was hoping for a google link to a manual or a parts diagram but cannot find one.
Does anyone here have this model of compressor. Is it any good for running models.
Mick
Thread: Adaptations for Arthritic hands
11/01/2017 09:22:43
I have a disorder called Sjogrens Syndrome, I have the systemic type so a lot of my joints hurt when I'm going through a flare so I know exactly how you are feeling. I just stay away from the woirkshop when I'm feeling bad and make hay when I'm not.
Thread: Milling Machine Vice
02/01/2017 08:08:36
I had a second hand Warco 80mm vice when I first started and the same thing use to happen to me, I even stripped it down but it still lifted.
Si I bought an Atlas vice from Cromwell tools, it was only £80 and it is a super piece of kit. So far no lift but the work must be knocked down pretty well.
Thread: Hi Folks
19/12/2016 15:04:48
Welcome to the forum Greg. I'm also from Nottingham and pretty new to model engineering scene as well, just kitted out my new workshop. I've yet to build any models, just making some tools at the moment.
Thread: What Did You Do Today (2016)
09/12/2016 14:54:11
Spent yesterday in the workshop making two drawbars, one for the Myford and one for the Sharp Milling Machine.
They work great and will be a good addition to the workshop.
They are both M10. The myford is the longer one. I made it so it goes through the hole in the door so I can have the guard closed while I'm working.
Edited By Michael Bird 1 on 09/12/2016 14:55:50
Edited By Michael Bird 1 on 09/12/2016 14:56:12
Thread: Need help on wiring a three phase motor
05/12/2016 18:15:56
Cheers John so 3/4hp about right.
So I'm looking for an inverter about 1hp.
05/12/2016 18:09:50
Thanks everyone for your help
Ok I understand what you are saying and it looks pretty easy to do. All I need now is to look out for a reasonable priced inverter.
The motor doesn't say what HP it is. I've been looking around at other motors with a similar spec and they seem to be 0.55Kw or 3/4 HP.
Is there a maths formula to work this out?
Edited By Michael Bird 1 on 05/12/2016 18:14:43
05/12/2016 16:27:15
Wiring info:
