Member postings for Peter Greene
Here is a list of all the postings Peter Greene has made in our forums. Click on a thread name to jump to the thread.
Thread: Email issues
16/11/2022 01:38:01
Microsoft is implementing OAuth2 all over and there are plenty of complaints in other places about email failure particularly if a non MS email client is used. (Imagine what the hardy band of Eudora users are going through!)
You are not alone.
Thread: scaling
15/11/2022 15:33:46
I would have thought that flywheels would be a problem with linear scaling.
Thread: Another EVRI calamity.
14/11/2022 18:58:48
Posted by Michael Gilligan on 14/11/2022 10:45:08:
This is all very clever; but is it progress ?
It does, at least, beat the "shipped - in transit - delivered" style of "tracking".
Thread: Bent thread
13/11/2022 22:44:14
Posted by Bill Phinn on 13/11/2022 20:31:15:
.... the section of bar to be threaded was first turned down to exactly 10mm ....
I would commonly turn it to a slightly lower dia (ref Tubal Cain in "Drills Taps and Dies) giving negligible performance loss but much easier threading (with a die).
(.... and to suggest thread-cutting as others have done ...up to a shoulder at that.... for someone who, by his own admission, is inexperienced in threading is unhelpful imo)
Thread: Another Smart Meter thread.
13/11/2022 01:42:26
Posted by Frances IoM on 12/11/2022 12:50:56:
Putin was at first looked on as one who could bring some stability to the post 1991 collapse of the Soviet Union
Not the way I remember it .... ex KGB, old guard and a serious future problem.
At least on this side of the pond.
Thread: Rust on New Lathe
11/11/2022 21:47:09
... but was it delivered corrosion (DC) or acquired corrosion (AC) and do you need a brush to remove it?
Thread: Modestly priced ER collets
11/11/2022 18:28:34
Posted by Michael Gilligan on 11/11/2022 11:14:04:.
Are you familiar with the word Tantric ?
My OED defines it as"loosely denoting the association of spiritual and erotic practices".
Not sure whether I'm more shaken by the collets or you Michael.
wink
11/11/2022 18:20:56
Posted by Tim Stevens on 11/11/2022 17:27:22:
Brushless doesn't just mean it's got no brushes, it means it also runs on DC.
In my day, brushless motors were properly called "brushless dc motors" ...you wouldn't have expected an ac motor to have brushes.
09/11/2022 19:28:14
Posted by SillyOldDuffer on 09/11/2022 10:18:28:
It looks like light rust to me too, but from the photos it's mostly on parts of the prismatic bed that don't matter!This lot is under the chuck where the saddle never goes:
If the rust is only where the saddle (et al) never goes, wouldn't that suggest a used machine?
Thread: Help needed with stiff Pratt Burnerd 3 jaw chuck.
06/11/2022 22:45:07
Posted by SillyOldDuffer on 06/11/2022 21:58:15:
...........it might be sinister.
You mean a left handed jaw? There's a thought!
I'll leave now.
devil
Edited By Peter Greene 🇨🇦 on 06/11/2022 22:47:22
Thread: Latest Scam
06/11/2022 22:39:47
Posted by Lee Rogers on 06/11/2022 11:23:48:
I think the fact that some one calling from Nigeria can cloak the call with a UK dialing code is the telecoms industries greatest failing. For years they have said that they can't do anything about it. The fact is that they can but they won't.
I'm fairly sure that the telephone company's computer knows the actual origin of any call. That means it should be possible for customers to elect not to receive calls from countries they choose. (Or it might be easier for customers to choose the countries they will allow calls from). They (the telcos) could even market it as a value-added service - a travesty but still ....
I won't hold my breath.
06/11/2022 20:38:34
Posted by Graham Meek on 06/11/2022 11:14:36:
Just to let people know the latest scam telephone calls received recently have come with our Area Code and realistic area number.
I'm surprised if that's something new in the UK. It's been common here for a number of years leading to the government insisting that the telcos "do something about it". Predictably that has led to absolutely no difference.
They use spoofed local numbers to make you think that the call is from someone living nearby - an acquaintance or relative - so that you will pick up. It's so overdone though that it has the opposite effect ... legitimate calls from friends and relatives are more than likely shunted to answering machines/services.
Thread: Magnet Material for Free Pendulum Clock
06/11/2022 00:52:25
May I comment as a total know-nothing greenhorn?
It was my impression that the timing of a pendulum clock is solely set by the length of the pendulum itself. If the pendulum is set swinging it will go back and forth at the same rate ... tick-tock. However because of mechanical (friction) losses it's amplitude will gradually reduce down to zero in the absence of some energy input either by weights in a mechanical clock or by the magnetic impulse in a solenoid clock.
I don't understand the reference to clock accuracy wrt the solenoid material. Surely it's the synchronicity (is that a word?) of what's driving the solenoid that matters.
Have I made a total twerp of myself?
Thread: Goodby Fax machine
03/11/2022 17:51:46
Posted by SillyOldDuffer on 03/11/2022 16:43:15:
The main problem with email for Two Factor Authentication is it's not immediate. Too many people check their email once a day or less which is too slow for an authentication check intended to speed valid transactions through the system.
... but, if they're sitting (as they would be) at their computer, trying to log on to online banking and the bank wants to do a 2FA, they'd certainly have pretty much instant access to an email that they are aware has been sent. It's not a "check once a day" case, it's check on demand (in my case all emails come direct to my machine - I don't have to go looking for them).
With only a landline, doing the second factor by phone is actually more problematic since it could be answered by someone else on another extension. And if that someone else has cognitive problems, you've probably missed the auth-no and have to start again (if the bank lets you).
Perhaps better for the blind/visually-impaired. Worse for the hearing impaired.
Frankly, I'd like to see the bank quantify the email vs phone security risks rather just parading out the "email is insecure" knee-jerking.
Edited By Peter Greene 🇨🇦 on 03/11/2022 17:54:21
03/11/2022 17:29:30
Posted by John Doe 2 on 03/11/2022 15:41:09:
Email can be read by people other than your intended recipient - potentially anyone in the World with a computer and an internet connection
OK, I have an email in front of me. Why don't you tell me what it says. While you're at it you can tell me what my banking log-on password is (2FA).
Edited By Peter Greene 🇨🇦 on 03/11/2022 17:30:23
02/11/2022 22:01:38
Posted by Peter Greene 🇨🇦 on 02/11/2022 14:19:48:
Posted by Martin Connelly on 02/11/2022 08:30:55:
...... as email replaced it as a means of communication.
... and I've experienced at least one business recently that will not communicate by email - it has to be by texting.
... and my bank has just started to go through 2-step verification every time a person logs on to online banking. But they won't send the code to an email address any more - either text or voice-phone.
02/11/2022 14:19:48
What next?
Edited By Peter Greene 🇨🇦 on 02/11/2022 14:20:14
Thread: DID I IMAGINE IT ?
29/10/2022 22:39:45
Posted by JasonB on 29/10/2022 14:56:48:
... again your comments were reported by other members
Anonymously of course... no public (in the thread) complaint.
There should be an smiley for nutless.
Thread: The Mitutoyo caliper for sale ad.
26/10/2022 22:27:51
There are a couple of other effects of removing the button too:
- one less area to coolant-proof.
- there is a minor (but always worth having) improvement in overall reliability numbers.
That said, most of the pictures on the Mitutoyo site seem to have the mm/in button shown (on the front).
Thread: Unfulfilled Orders
26/10/2022 22:17:20
Still very coy. We can assume there are probably a few booksellers out there that behave like this so what does this thread tell us that we didn't already know?
