Member postings for Martin Connelly
Here is a list of all the postings Martin Connelly has made in our forums. Click on a thread name to jump to the thread.
Thread: Rear tool post vs front tool post
23/03/2023 12:42:14
Sorry JA, clearly wrong. The lathe can be used either way if the chuck will not be unscrewed. So between centres, collets, bolted on chucks and D1 type mounted chucks can be used either way.
See this threading technique where the part is spun in reverse with an inverted tool to cut R/H threads with the tool moving away from the headstock.
Martin C
Thread: Warco V Belt Change
19/03/2023 19:21:03
Page 17 of the Warco manual strongly recommends removing the idler pulley when using one long belt.
Martin C
19/03/2023 09:02:38
If you look at the picture of supplied parts in the Clarke manual there are 4 drive belts. Overly complicated system it seems. I can see why a VFD would be preferable as John has found out.
Martin C
Thread: land line problem
18/03/2023 18:05:11
I have had this from BT SMS service calls when someone sends a text to a landline. I think it went away after another one came through and I chose to delete it.
Martin C
17/03/2023 12:51:53
Look at page 21 of this Grizzly manual for their version of this machine. It also suggests loosening the idler pulley nut but shows a view of the nut they are referring to.
Grizzly CL4015Z manual
Martin C
Edited By Martin Connelly on 17/03/2023 12:54:30
Thread: 5C minimum grip length
15/03/2023 12:58:42
As with many such questions there is not a simple yes/no answer. On the basis that it is a single taper I would suggest it does not have a minimum, as long as the part being held is sized to suit the collet and can take the pressure of all the closing force on a small area. If you look at ER collets for small diameters they do not support the part all the way along the collet but larger ones do and need something to be gripped nearer the back as well as at the outer lip. Also, don't try large cuts on a part held by very little contact or have a long, unsupported, stick out from the collet. If you use soft jaws for something like a washer it is a very similar work holding method apart from there being a shoulder behind the part that will also resist pressure from things like drilling. With a 5C you can add a back stop to resist pressure from the front.
Martin C
Thread: Advert in the photo albums
15/03/2023 12:41:03
One for the moderators to check
Martin C
Thread: French door locks
14/03/2023 16:38:27
Try these people, they may know someone else if they can't help Lowe & Fletcher
Martin C
Edited By Martin Connelly on 14/03/2023 18:42:56
Thread: Can a touring caravan be disassembled and then reassembled easily?
13/03/2023 08:38:45
I copied Tommy Walsh's basic design to build my own.
Martin C
PS I didn't put in any glazing and only made a plain gable ended roof (but plenty of lighting).
Edited By Martin Connelly on 13/03/2023 08:40:51
Thread: Quiz show question re alloys
12/03/2023 08:13:56
It was on Bridge of Lies. You had to decide which one of a number of statements was correct, the others being incorrect. This statement that prompted this thread was "all alloys contain metal".
Martin C
Thread: Why is the world of model engineering still imperial?
11/03/2023 13:50:18
You can also create a post in Word or some other suitable word processor then copy and paste into here like this:
x2 x3 x4 x5
x-1 x-2 x-3 x-4 x-5
Or even just copy from this post and paste into your own text
Martin C
Edited By Martin Connelly on 11/03/2023 13:50:44
Thread: What’s wrong with my knurling
11/03/2023 08:05:46
Here's Joe Pie's video on this subject:
Martin C
11/03/2023 07:58:48
JA look at this thread for my post on 8 Jan 23 Special characters
Martin C
10/03/2023 16:29:41
JA m/s² m³
Martin C
04/03/2023 08:48:26
Surely the claim that understanding the values 0 to 5 thou is better than the metric equivalent is simply personal preference. As someone who had to work in both units for most of my working life I know that 1mm is about 40 thou (39.37, close enough for estimating which is what people are suggesting here) so 4 thou is about 0.1mm 1 thou is about 0.025mm. I can add 0.1 and 0.025 and combinations of these to get 1, 2, 3, 4, 5 thou, and vice versa, without having to resort to paper and pencil or calculator.
Martin C
Thread: Removing masking tape
01/03/2023 11:50:10
SOD you missed off vegetable oils as used in cooking. They are pretty harmless and may need a bit of time to soak through the adhesive but are also usually available and cheap.
Martin C
Thread: Clarkson 4" Hi-flow cutter
01/03/2023 08:43:33
7/8" is 22.225mm so I would guess 7/8" 12 TPI but would use a thread gauge to check if it is a 60° or 55° angle thread. You may be able to get a good macro picture with a digital camera or phone camera that you can measure with a protractor. There was a recent thread regarding the smaller threaded tooling for Autolock chucks and they use 20 tpi Whitworth (55° ) threads. Recent discussion on endmill threads
Martin C
Edited for unwanted smiley
Edited By Martin Connelly on 01/03/2023 08:44:58
Thread: Myford thread
28/02/2023 10:46:30
A set of thread gauges would be a useful tool to have. As well as checking what you have now they will come in useful in the future as well. Look for 55° Whitworth form, 60° Unified form and 60° Metric form. If you can get a chuck on to the point where you can do some work consider making a dummy spindle nose in aluminium that you can use to check backplates and faceplates without risking damage to the lathe's spindle nose. A dummy spindle nose is also useful if you want to machine your own backplates or faceplates.
Martin C
Thread: I have made a boob
26/02/2023 14:28:13
Without knowing what equipment you have available to use make suggestions a bit hit and miss, but my go to for this would be to hold the head in some soft jaws that have been turned to suit the part.
Martin C
Thread: Steel for tool holders
24/02/2023 14:38:58
Ø6 button tools are great for machining plastics where the forces are a lot lower than when machining metal.
Martin C
