Here is a list of all the postings Chris Evans 6 has made in our forums. Click on a thread name to jump to the thread.
Thread: Laser cut steel suppliers |
09/02/2023 08:13:23 |
Here in the Midlands I use NRS Laser in Tamworth. |
Thread: Sunbeam B24 350cc 1939 |
16/01/2023 17:03:28 |
The BSA on my Avatar was very incomplete and in worse condition than the Sunbeam when I started to rebuild it. Lots of happy hours in the workshop have a value to me, sure I would lose money if I sold it but that misses the point.Rebuild for mechanical reliability and safety that will keep its value up and not consume thousands on cosmetics. Do you know if the engine turns ? |
Thread: 1/4" " angle Drive In Hydraulic Grease Nipples |
14/01/2023 17:50:54 |
Plus one for "The Nipple Shop" |
Thread: Machine plates fixing |
06/01/2023 15:46:18 |
When I was still working I used to buy them under the "Taptite" brand name. |
Thread: Tool and Cutter Grinder Air Bearing |
30/12/2022 17:35:00 |
I have an American "Cutwell" (sold by Brierly (sp?) ) 90 psi is required. |
Thread: I found this old car but what is it? |
30/12/2022 17:29:29 |
Posted by Nigel McBurney 1 on 30/12/2022 11:52:48:
Best place for it,only rode in one post war sit up and beg Ford for a few miles ,awful ride, I was once asked to help a friend to get the rear brake drum off a similar Ford ,I could not get it off apparently a special puller was required as the drum and hub were in one piece and I was later told that it was a taper fit on the half shaft. Thats also just like the rear hub on a Triumph Herald ,taper and key fit,another friends car ,a really big screw puller would not move it, so it went to a local garage where they used a hydraulic puller and then had to nearly burn righ through the hub with oxy torch and it then flew off with some force.They did it and saved the half shaft. I will concur re E93A 8 or 10 hp. I still have a rear hub puller somewhere deep in the workshop. I built a sporting trials car based on an E93A and also used one as a daily driver. Fitted with an Aquaplane hear and a Judson blower and SU carb set up things could get a bit hairy. |
Thread: Equally spaced holes |
28/12/2022 21:06:52 |
I have a spare three jaw chuck mounted on a rectangular plate. I can clamp to mill table or put it into the machine vise. A useful bit of kit. |
Thread: New Member from West Midlands. |
12/12/2022 11:10:21 |
Welcome along Stuart, I am also in the West Midlands a few miles north of Lichfield. Vintage motorcycles for me I don't make models but find them interesting. Enjoy the hobby and your retirement. |
Thread: Chinese diesel heater |
11/12/2022 13:57:33 |
Posted by Alan Wood 4 on 11/12/2022 13:06:06:
Mike T - it could be the diesel going soapy. My pump is mounted vertically as recommended and is well wrapped with insulation to try to minimise the ticking noise. I have not insulated the header tank even though the whole assembly is mounted outside albeit fully enclosed (see blog image). The enclosure is a double decked affair with the heater on the lower level. The residual heat from the heater therefore warms the inside of the enclosure with the header tank directly above the heater. The fuel and the pump therefore benefit from protection. Re vertically mounted pump, on the Eberspacher the pump has to be at an angle to work. Mine is around 60 degrees and works with heating oil and diesel piped up from a floor mounted beer barrel. |
11/12/2022 11:53:22 |
For the last 9 years I have used an Eberspacher D5 heater in my garage (double garage full height of the house). A heath robinson installation done for me by a friend as payment for some machining work. Very good heater enough to take the chill off and be comfortable to work. The heater was second hand and runs from a 240 to 24 volt transformer. Air inlet and exhaust go through the 9" wall to outside and very frugal to run, I use regular diesel, red diesel or heating oil depending on what I can get hold of. Just payed £0,78 litre for heating oil, 50 litres will do two or three winters depending on weather and workshop activity. I believe the exhaust length is critticle for these heaters but that is only what I was told so not sure if true. |
Thread: RYAZAN 1M63 Russian Manual Lathe |
02/12/2022 10:53:43 |
When I was managing a mould and die shop we bought a couple of Stanko milling machines. Real big beefy things that replaced Adcock Shipley 2S which was worn out in under two years. The Stanko mills could really shift metal, came well equipped and had a feature to mill a square or rectangular pocket using the traverse switches, Apart from 1950s style electrics that could be troublesome they where good machines. Imported by a company in Warwick (MTA) Maybe Michael's suggestion will show a similar machine to your lathe ? |
Thread: Another new member |
01/12/2022 08:25:18 |
Welcome along John. |
Thread: Can anyone help to identify the make/model/year of this 1930's motocycle? |
26/11/2022 08:41:37 |
I have a 1920s and a 1930s BSA Sloper and do not think it is one. Genny addition looks home made and the front mudguard looks wrong for a BSA. |
Thread: Progress... |
23/11/2022 09:09:31 |
Very nice and you do look happy. I doubt you will keep the oil cans on that nice toolbox for long, if they are like mine they will leak and be messy. Enjoy the mill. |
Thread: Good tweezers? |
21/11/2022 09:10:39 |
Posted by Sam Longley 1 on 20/11/2022 10:03:01:
Posted by Chris Evans 6 on 19/11/2022 11:20:43:
I made my tweezers from a hacksaw blade with a nut and bolt through the holes and a nut as a spacer. This was to remove a splinter from my finger. 40 years on they are still the best I have. Any chance of a picture please? Sam, I can no longer post pictures due to complexity of getting my phone and computer to link up. PM me your email and I will try and send a picture to you. Chris. |
19/11/2022 11:20:43 |
I made my tweezers from a hacksaw blade with a nut and bolt through the holes and a nut as a spacer. This was to remove a splinter from my finger. 40 years on they are still the best I have. |
Thread: Taylor Undertype Engine |
30/10/2022 20:36:46 |
I seem to remember drawing colours/shading in my copy of "Fowlers Machinists Handbook" from 1933. Next time I am in the workshop I will have a look to see if there is anything to add to the thread. |
Thread: Any info about what machine this slotting head is for? |
20/10/2022 09:10:32 |
Looks very much like a shop/home build. certainly not a commercial built job. |
Thread: New Member |
25/09/2022 09:32:12 |
Welcome along John, enjoy the forum. |
Thread: Vertical Milling Heads - Are there any published designs? |
13/09/2022 12:13:23 |
Posted by Jelly on 12/09/2022 23:48:35:
Posted by Vic on 12/09/2022 16:49:57:
Posted by Baz on 12/09/2022 15:50:30:
Now that Huron is a proper mill, what a beautiful machine. I was thinking the same thing. Some folks lust after the old Bridgeports but I’d far sooner have something like that Huron. Whilst it benefits from amazing brand recognition, the Bridgeport isn't even the best Bridgeport Clone... TOS's FNK25(A) and Shizuoka's VHR(/G) both blow it out of the water on features, rigidity and performance whilst being cheaper new (and probably cheaper now due to not being "the" brand). .I have used Deckel and Schaublin mills and also worked a Huron for many a happy hour. All are good but I think the Huron is slightly better, Droop and Rhine (spelling ?) also figure high on my list. Retirement sees me with a Bridgeport turret mill and does all I will ever need. It's a long-term ambition of mine to own a Huron (and by extension have a workshop big enough for that to be sensible), they are far and away the best designed and most ergonomic to operate of all the ram-type "Euro-Mill" machines (including the Deckels and Schaublins) a lot of effort clearly went into making them easy to operate no matter what possible use case you had for one... It's just unfortunate that they only made them in a size range from "That's really quite a big mill isn't it?" to "Ah, so you'll be wanting to machine the column casting of a Bridgeport now will you?"
