Any info about what machine this slotting head is for?
Charlie Simpson19/10/2022 21:13:57
2 forum posts
Hi,
First post.
I have recently acquired a manual slotting head that I am refurbishing (see attached) which has a mounting bracket with a 76mm bore and a brass locking clamp, does anybody know what machine this was meant to be used on?
Imgur Gallery
Many thanks,
Charlie
Chris Evans 620/10/2022 09:10:32
2156 forum posts
Looks very much like a shop/home build. certainly not a commercial built job.
Michael Gilligan20/10/2022 09:17:31
23121 forum posts
1360 photos
I agree with Chris … so the answer is:
Any machine that you can reasonably fit it on.
I’m sure the maker had a specific machine in mind; but we could be guessing forever.
Hopper20/10/2022 09:30:55
7881 forum posts
397 photos
It could even be made to clamp on the overarm of a small horizontal mill, of which there would be many to choose from. Looks like it could make a handy addition to the cross slide of a lathe so you could hold the job in the lathe chuck, index it via the changegears and then cut your slots, splines, gear teeth, graduations or whatever with the device.
Daggers20/10/2022 11:38:40
52 forum posts
I think Hopper has likely guessed the correct use.
Assuming the ring of cap head bolts shown on the collar attach to the main slotting head plate. This means that when the collar mounts onto a shaft which is horizontal the action of the slotting head would be vertical.
So a likely candidate would be a horizontal milling machine with a 3” diameter bar.
Nick Clarke 320/10/2022 14:31:55
1607 forum posts
69 photos
The size is correct for a Drummond Round Bed (model A), but as has been suggested probably home made.
If I had more time I might be tempted to look through Edgar T Westbury's articles in ME from the start of the second World War on capstan and turret lathes, but tempus fugit I'm afraid!
Edited By Nick Clarke 3 on 20/10/2022 14:43:39
1607 forum posts
69 photos
Duplicate post
Edited By Nick Clarke 3 on 20/10/2022 14:43:56
Charlie Simpson20/10/2022 22:36:54
2 forum posts
Thank you all for replying and answering my question it has been very helpful.
Charlie
