Here is a list of all the postings Chris Evans 6 has made in our forums. Click on a thread name to jump to the thread.
Thread: Hello from Wolverton, Buckinghamshire |
23/02/2021 19:39:08 |
Welcome along Jake. |
23/02/2021 19:39:07 |
Thread: Hello from East Anglia |
21/02/2021 09:52:42 |
Welcome along, enjoy the forum. Ask away with any questions there is a wealth of knowledge on here. |
Thread: thresher belts |
21/02/2021 09:48:56 |
When I ran a Southbend lathe leather belts and the joiners where still available from agricultural merchants and the industrial power transmission suppliers. Try "Fenners" which I believe is now branded as "Erik's" |
Thread: Motorcycle footpegs |
19/02/2021 19:48:54 |
Posted by Stuart Cox 3 on 19/02/2021 19:45:01:
Posted by Chris Evans 6 on 19/02/2021 19:39:01:
Very nice and a lot easier to machine than the aluminium bronze I have just done a batch of Matchless G15 CSR brake peddles in. The reason I had aluminium bronze castings is that they will bend rather than snap if the bike is dropped. Ali/Brz is not nice to machine. Bet it looks nice though! ....any pics? Castings are still not fettled as yet only the machining is done so they still look rough. I will try and get a picture if I can remember how to post it. |
Thread: Dickson holder storage |
19/02/2021 19:45:24 |
Like Oldiron mine are on a shelf bolted to the splashback. Trouble is the shelf is also handy for lots of odds n sods like boring bars and threading tools. All equals an untidy mess due to lack of personal discipline. |
19/02/2021 19:39:01 |
Very nice and a lot easier to machine than the aluminium bronze I have just done a batch of Matchless G15 CSR brake peddles in. The reason I had aluminium bronze castings is that they will bend rather than snap if the bike is dropped. Ali/Brz is not nice to machine. |
Thread: What tool to use please |
18/02/2021 19:04:53 |
I suppose it helps running a Bridgeport and a choice of 10" and 14" rotary tables. The big rotary only gets used about once a year but I could not part with it. |
18/02/2021 15:23:18 |
I would cheat and profile the diameter very close on the mill/rotary table. |
Thread: O ring groove profile |
18/02/2021 09:14:49 |
Posted by David Marks 2 on 18/02/2021 09:12:14:
Normally the manufacturer/supplier of the O ring will have a data sheet which defines the shape/size of the housing into which the O ring is to be fitted. Try (for example) the data available from a company such as James Walker who manufacture O rings. That has roused my memory. It is the James Walker charts I have in the workshop somewhere...….. |
18/02/2021 09:09:55 |
No need for a snug fit. The "O" ring needs somewhere to expand into, charts are available showing all the dimensions to use. From memory a 0.070" section seal needs a groove width of around 0.090" and depth of 0.051" Check the above sizes before committing, it's been several years since I used "O" seals. |
Thread: Metric internal thread cutting dimensions |
16/02/2021 17:35:54 |
I think your problem may be with the "Truncating" of the thread form due to the insert not being full form. When I screwcut I always end up going a few thou deeper than the book size. Usually get to fit and function rather than measure over wires. Internal threading really requires a gauge that I do not possess. |
Thread: Tools and equipment loan list/surplus list |
15/02/2021 19:55:21 |
I once made a bunch of special tools for old series Land Rovers and started to lend them out to folk on a Land Rover forum. I asked for a £20 deposit to ensure things came back to me but some folk just kept the tools and never answered e-mail chasing. A pity because it was a good service to the forum. |
Thread: Back plate metal choice |
15/02/2021 19:41:06 |
Plus another one for SG cast iron. For one offs I tend to make a pattern from polystyrene and get a foundry about 25 miles away to cast for me. Not the cheapest approach but you are in control of the amount of machining stock left on. |
Thread: Belt tension |
15/02/2021 15:33:51 |
I have seen a "Gates" catalogue giving information on useage. Maybe worth a look online. |
Thread: Under size rod for bearings |
14/02/2021 10:05:05 |
I doubt if adjustable reamers go down that small. You will need the 0.05 to make it run easily, the oil/grease will use up some of the clearance. |
Thread: Pipe bending |
14/02/2021 09:14:34 |
An interesting subject, I have managed to make a rear carrier for a vintage motorcycle from 12mm diameter x 1.5 mm wall section tube using a cheap DIY plumbers bending kit. I just used the formers for 15mm copper pipe and the results where good with very little if any "Necking". For bigger diameter tubes maybe one of the motorcycle exhaust pipe makers could help ? |
Thread: Indexable Lathe Cutters advice. |
11/02/2021 09:23:13 |
This brings up the old advise not to buy sets but buy individual items as needed. |
Thread: Small Lathe Advice? |
10/02/2021 14:17:39 |
Andrew, to what purpose do you want the lathe ? Model making/general repairs/car restoration/motorcycle work, clock making or just nice to have. Myfords are very popular and seem to punch well above their weight. To suit the work I do I have a 14"x40" 3HP lathe, overkill for a lot of people. |
