Member postings for Georgineer
Here is a list of all the postings Georgineer has made in our forums. Click on a thread name to jump to the thread.
Thread: Moore and wright tools
20/02/2023 17:54:20
Frank,
I'm not sure why you don't want to start a new thread, but I would have found a new thread with a meaningful title more helpful than an exhumed thread from five years ago.
George
Thread: Introduction
20/02/2023 17:50:04
Andy,
Your lathe is most likely to be an ML4 as they were most common by a long way. There is a lot of information already on this forum. The trick is to start with a search for "ML4" which brings up (at present) 48 topics. When you've read them, try ML2, then ML3 and finally ML1. You'll learn a lot,
George
Thread: Ideas for highlighting engraved digits
10/02/2023 14:19:10
Posted by Richard Millington on 10/02/2023 13:02:26:
When I used to do repaint my motorbike control legends I used Humbrol enamel put into the engravings and the excess wiped off with a piece of lint free rag.
The instrument makers where I worked used newspaper to wipe off the excess, as it's non-absorbent and doesn't leave fibres. As noted elsewhere, engravers' wax is good. I also got red, white and black off the internet for not much money, and it works well.
George
Thread: Cigarette Papers
08/02/2023 16:34:42
Posted by duncan webster on 08/02/2023 14:29:55:
Posted by Georgineer on 11/08/2020 12:09:46:
... with paper, thickness is defined by weight and area. Easier and more useful to weigh bulk products like paper than to micrometer individual sheets, which vary with compression etc. ...
This was valuable knowledge when I was a Science teacher. An A4 sheet of 80 gsm paper weighs 5 grams, and there was an accurate balance in the prep room. No need to count the worksheets - simply weigh 'em out and weigh 'em back in - "Two more worksheets to come back, please." It worked every time.
It also worked with connecting leads, any other small components, and plasticine. Especially plasticine - it's very satisfying to see kids scrabbling about to find the pellets they flicked at their mates, when really they want to be going to break!
George B.
What about the ink?
That was only an issue when I was a pupil. We had nearly covered the form-room ceiling with wads of chewed paper flicked up with a ruler, and some idiot soaked his in ink.
Form master noticed, and it was class detention to get them all down again with brooms... Can't reach? Stand on the desks!
George
Thread: O Ring Kits
23/01/2023 17:16:51
Posted by mick H on 23/01/2023 07:17:44:
Not wishing to teach anyone to suck eggs,
Ah yes:
"Teach not thy parent's mother to extract /The embryonic juices of an egg by suction./That worthy lady can herself enact,/Quite irrespective of thy kind instruction." Boy's Own Paper, April 29, 1882.
The problem I have found with O-ring kits (along with other kits in compartmented plastic trays) is that they seldom list the dimensions of the parts in the compartments.
George
Thread: Drill Press Improvemnts
23/01/2023 16:58:44
I like the depth stop modification - I shall steal the idea for my drill press.
Does the belt guard actually need a catch (or a screw)? Mine has functioned perfectly safely for decades without either.
George
Thread: Please help
14/01/2023 15:51:44
Dell,
May I politely request that you use a meaningful thread title? That way, you are more likely to get the help you are asking for.
George
Thread: Information required for making Meccano Spur gears
11/01/2023 23:22:14
Posted by JasonB on 11/01/2023 15:51:11:
If you follow the other links it was so the gears worked with their 12tpi racks which were a 55deg V form
That makes sense. Back in the 1960s I wanted a left-hand Meccano worm gear. With my metalwork teacher's help I established that the standard worm gear is actually a 12 tpi Whitworth thread (9/16" daimeter if memory serves), so I cut the equivalent LH thread on a length of brass and made my own worm gears. I even bought my own 5/32" BSW taps to cut the thread for the grubscrew.
The school, for some reason, didn't have a left-hand thread chaser, but the right-hand one did a perfectly acceptable job.
I've still got one of the LH worms knocking around the place somewhere. And the taps...
George
Thread: Yet another scam
26/12/2022 12:37:38
Posted by KWIL on 25/12/2022 12:23:14:
When faced with form that requires (mandatory) a telephone number (to assist delivery?) simply use exchange number followed by 000 000, computer sees enough digits even if it is unusable.
I've found that 01234 567890 is very acceptable to these systems.
George
Thread: Christmas Cracker Jokes
26/12/2022 12:32:09
Posted by Nigel Graham 2 on 25/12/2022 14:50:09:
Penguins can't fly because they are as non-aerodynamic as Kit-Kats.
That may not be a handicap. A friend of mine, who was a member of the local model aeroplane club, entered a chuck-glider competition with a brick, to which he had added two stubby wings and a smily face.
He came second, much to the annoyance of the serious competitors.
George
Thread: Repair cafes
12/12/2022 20:35:34
I should add that often the most difficult and challenging part of a repair, when the owner is present, is out-thinking the idiot who designed the casing and actually getting inside the appliance. Fortunately there are many how-to-do-it guides on the internet which can be called up on laptops or mobile phones, and the best of them can be very helpful. The worst of them...
George
09/12/2022 17:43:19
I've been a volunteer at the Portsmouth Repair Café for over a year and have thoroughly enjoyed it. I certainly haven't picked up on any of the negative or nervous vibes that seem to permeate some of these posts. We do a monthly café on a Saturday morning in a local church hall, with an occasional pop-up at Southsea Library.
The overall Repair Café organisation has been running for, I think, ten years now and the legal and liability issues are well established. As such I have not troubled myself unduly about them.
Broadly, the rule is that the owner must be present throughout the (attempted) repair. They sign a disclaimer beforehand acknowledging that success is not guaranteed, and that they accept the risk of further damage to the item. We don't repair white goods, collect and deliver, or take things away to repair. That said, we make exceptions in special cases subject to consent from all parties. After all, as my father used to say, rules are for the obedience of fools and the guidance of wise men.
All our volunteers stick within their own range of competence, but we have some very competent people and offer tool sharpening, jewellery repairs, fabric and needlework, clockmaking, cycle, electronic, software, electrical, metal- and wood-work repairs, and other specialisms. Each volunteer brings their own tools and such materials as they expect to need, and there is a central stock of commonly used things. We operate a booking system so it is often possible to diagnose and plan in advance. There is a very good culture of sharing experience, tools, materials, advice, skills and humour. New volunteers are offered the chance to buddy-up with somebody more experienced for as long as they want to before they fly solo.
I would say that most of our requests are for repairs to household electrical items, and we have a very good success rate with them. Those of us who tackle them all have knowledge and experience and we have no prima donnas, so seeking advice when needed is normal. The café owns its own PAT tester, and there are qualified and experienced testers among the volunteers, so electrical safety is taken seriously.
As its name suggests, it is a café, so it is as much a social occasion as a technical one, and we are kept well suplied with hot drinksand cake. I have yet to encounter a client who is demanding or unpleasant; on the contrary I have had many pleasant and interesting conversations while working. The café is self-supporting and is largely financed by donations from our clients.
Robin, I suggest that if you are interested you go along and have a look. If it appeals, give it a try!
George
Edited By Georgineer on 09/12/2022 17:45:45
Thread: How on earth do you make a Fire Hose
29/11/2022 21:59:51
That looks great! And thanks for letting us know the outcome.
George
Thread: Words and phrases
15/11/2022 21:23:24
Posted by old mart on 15/11/2022 20:09:59:
180%
180°, surely? Or 200° if you're in the USA.
George
Thread: machine light
30/10/2022 13:46:54
I'm looking for a machine light so checked it out. Three thoughts:
1. I don't get on with touch-switch lights. They're temperamental when alive, and when dead they turn up in large numbers in the charity shop where I volunteer.
2. A "g" rating for efficiency is very poor for a LED lamp. The touch-switch circuitry may have something to do with it.
3. Two one-star reviews complain that it has a "drooping neck" problem.
Thanks for the link, Dave, but I think I'll keep looking.
George
Thread: The cheek of McDonalds
18/10/2022 21:03:02
Posted by Nicholas Wheeler 1 on 18/10/2022 19:28:20:
And I wonder how Bill justifies what passes for food if he's never tried it?
Probably the same way that I do - I have to pass one quite frequently, and just the smell is enough to put me off.
George
Thread: Bending piano wire
09/10/2022 17:03:11
Just a wild guess, but is the original hardening achieved by work-hardening? If so it may not be possible to recover the original hardness. I believe that's the case with phosphor-bronze springs.
Can anybody out there with more knowledge and experience than me chip in?
George
Thread: Number drills?
05/10/2022 16:21:12
When I was at school I made my own by drilling all the holes a size smaller, then using the final size as a reamer in each hole. I still have it, and it has served me well over the last fifty-something years, but I hardly use it these days. Like Jeff, I usually use a drill chart and a digital caliper on the rare occasions when I need to know.
George
Thread: Ideas on how to form the joggle plate for a small tool makers clamp
29/09/2022 15:58:43
Posted by roy entwistle on 29/09/2022 15:15:04:
You don't really need one, the clamp will work without it.
What Roy said.
None of my clamps has one, and neither did any of my father's. They've served us well for nearly a century.
George
Thread: Myfor ML7 main spindle replacement
27/09/2022 18:19:47
Posted by Ady1 on 27/09/2022 18:09:28:
Bore it out for MT2?
Would probbly be more useful than MT1 anyway
Ady: I think Myford beat him to it. The ML1-2-3-4 mostly had a MT1 taper, but as far as I know the ML7 always had MT2.
Mick: Unless the internal taper is really, really bad I would have thought it was better to reclaim it with a MT2 reamer. For normal purposes the taper doesn't need to make 100% contact, so a few scroops won't matter. It might even be possible to turn a couple of thou off the existing taper before reaming, though you might need to get inventive with your boring bar.
It certainly sounds like a lot less work and money than changing the spindle. Has anybody else ever tried this and can offer opinions?
George
Edit : Some people type faster than me!
Edited By Georgineer on 27/09/2022 18:21:07
