Here is a list of all the postings Brian Sweeting has made in our forums. Click on a thread name to jump to the thread.
Thread: Automatic Centre Punches |
23/09/2018 19:45:35 |
Proverbial youtube link here might help.
Edited By Brian Sweeting on 23/09/2018 19:46:20 |
Thread: Engine room telegraph |
22/09/2018 19:49:26 |
According the HMS Belfast, it was used to signal pumping fuel to another vessel. |
Thread: I finished a project! |
07/09/2018 20:39:55 |
Excellent work Neil. |
Thread: Mystery lathe on eBay |
03/09/2018 22:16:11 |
Have you asked the seller for details yet? |
Thread: Joint Round Edge Needle Files |
31/08/2018 15:13:24 |
Ketan, found s site different from above link which details them as used by jewellers and watchmakers, uses shown on link page. **LINK** |
Thread: vapour carburetor |
14/08/2018 20:39:31 |
Have you seen the carbs made by Jan Ridders? They are glass cylinders or glass end plates. http://ridders.nu/Webpaginas/pagina_1-cilinder_glas_4takt/1cil_glas_frameset.htm
Thread: Peace Flame |
13/08/2018 16:10:11 |
As Michael has indicated, you do need a pressure regulated output. |
Thread: Crankshaft repairs |
07/08/2018 21:35:23 |
As a novice to this type of work might I suggest getting some basic material to practice the machining work and technique before starting on the final piece. |
Thread: What Is The Most Beautiful 'Thing' In The World? |
04/08/2018 22:20:33 |
Going against V8eng but ... Simple, a new born baby - human or animal. They are amazing. Edited By Brian Sweeting on 04/08/2018 22:22:27 |
Thread: A Replacement circuit board |
03/08/2018 15:43:25 |
Came across someone who fitted an Ardunio system instead if this is feasible. |
Thread: Cast Iron Weights -Aldi |
01/08/2018 00:15:38 |
Sorry if this is in the wrong place. Just seen that Aldi have sale on and one item is 4 x 2.5kg weight lifting disc weights at £ 4.99. Could be pullies or handles? |
Thread: Help needed with Lancer Boss forklift and Borg Warner T12 trans |
28/07/2018 15:25:45 |
Just a thought on your oil change. How much oil came out first against design capacity? How much did you put in? |
Thread: Neil's Irrelevant Press Release Thread |
24/07/2018 13:10:10 |
They do make you wonder sometimes don't they? My classic is on supermarket shelves already - Recycled Toilet Paper, not for me thank you. |
Thread: KIM drill press |
19/07/2018 20:02:59 |
Apart from finding out that it was made in Taiwan I haven't been abe to get any other info, sorry. |
Thread: Digital RPM Display Problem |
16/07/2018 14:55:37 |
What the gap between the magnet and the sensor? Could be a faulty sensor. Does the sensor led flicker when the magnet passes it? |
Thread: Is this really a clock? |
12/07/2018 23:36:32 |
The guy just didn't know when to stop cutting gears. |
Thread: another mystery object |
12/07/2018 15:40:22 |
Looks like a type J. Wire colours - **LINK** |
Thread: Age related macular degeneration. |
11/07/2018 16:05:35 |
Is your condition 'dry' or 'wet' as a friend of ours has wet and any info is useful.? |
Thread: Work bench to mount lathe |
10/07/2018 22:16:59 |
I have to admit that my mini-lathe is mounted higher than my suggested elbow height to save me bending over the workpiece so much. |
10/07/2018 11:06:32 |
Some people say that with your elbow at 90° your hand should fall onto the cross slide operating handle. Also consider how bent your back may be when watching the work piece and turning the controls. |
