Here is a list of all the postings john carruthers has made in our forums. Click on a thread name to jump to the thread.
Thread: Dark Lady Clock |
09/07/2016 17:48:36 |
In the plans Brian suggests taking the motor off the drill press temporarily and using that. |
09/07/2016 13:31:36 |
09/07/2016 08:09:38 |
Yesterday I started on the minute and reverse minute wheels. All kinds of bother with the spindle, belt too loose it slips, too tight it doesn't turn (or with reduced power). |
Thread: Lock making |
07/07/2016 08:09:13 |
Richard Sharpe: Gimme a pick-lock, Cooper. Cooper: Pick-lock, sir? Catch me with a pick-lock! Patrick Harper: They did, Coop. But when you got out of Newgate prison, you got another set, and that's the one the officer wants. Cooper: Do I get it back, sir? Richard Sharpe: Trust me. Cooper: It's very hard to trust a man who wants to borrow your pick-lock, sir. |
06/07/2016 10:49:05 |
Now that I know it has a chance of working I shall put a bit of effort into the finish of the parts; cross out the wheels and spot the flat parts. |
05/07/2016 17:12:45 |
Today I made the foliot and it actually ticks. |
Thread: Tip for the week |
01/07/2016 08:40:21 |
A discarded roof slate screwed to the wall of the shed over the lathe and a bit of chalk for jotting numbers and reminders. I live on aprox 12 billion tons of chalk so no shortage.
28/06/2016 18:06:00 |
I have to make hay while the sun shines Neil, might be back on the morphine tomorrow |
Thread: sieg sc3 mini lathe precision ? |
28/06/2016 18:00:55 |
Hi Zuji, I have an sc3 and can, when necessary, work to +- 0.01mm with a sharp tool. If a better fit is required then grind or file and paper it. |
Thread: What Did You Do Today (2016) |
28/06/2016 17:51:54 |
>>but no way to 'borrow' a few as security is tight<< |
28/06/2016 17:48:26 |
Today I made a few screws and the verge/pallet. |
26/06/2016 17:48:27 |
It's coming along John thanks, I planted the train today and it runs with a piece of brass tied to the cord as a weight. |
Thread: Clarke Metal Lathe CL300M |
25/06/2016 16:59:55 |
deleted post, I see you've sorted it. Edited By john carruthers on 25/06/2016 17:01:17 |
25/06/2016 16:55:45 |
24/06/2016 16:25:15 |
Try putting them on a bed of silver sand or brass swarf, then heat slowly from underneath.
Thread: Building a GOTO Mount |
24/06/2016 08:06:38 |
I've fettled a few mounts that use a friction drive rather than the traditional wormwheels. No backlash, but a small chance of slipping under acceleration, which can be ramped up and down of course. Edited By john carruthers on 24/06/2016 08:12:48 |
Thread: Secrecy...within the workshop? |
21/06/2016 06:35:41 |
>>of my working life & the silverers were very secretive about the mixes for coloured silvering<< |
18/06/2016 10:38:31 |
Thread: What do I use to run my oscillating engine? |
18/06/2016 07:43:43 |
Old fridge compressor? they are very quiet.
Edited By john carruthers on 18/06/2016 07:44:17 |
17/06/2016 07:49:46 |
Very true Brian, we used them extensively in the glass trade for edge grinders etc. One of my jobs was to thrash them on the bench then give them a good hammering occasinally to loosen the glass dust which set like concrete. Edited By john carruthers on 17/06/2016 07:50:40 |
