Here is a list of all the postings Mick Henshall has made in our forums. Click on a thread name to jump to the thread.
Thread: What Did You Do Today (2017) |
20/10/2017 07:15:45 |
Yes Geoff, I have them on my Boxford shaper,never quite sure if enough oil is getting where I want it, short of dismantling the machine to remove them by driving out from underneath how can they be removed? When I got my shaper it was stripped and these oilers were blown through to clear and they seemed fine now am not so sure Mick |
Thread: John Stevenson |
20/10/2017 07:06:35 |
Don't know you personally John but have read your posts and it is obvious you are well thought of so I would like to add my well wishes for a speedy recovery Regards Mick |
Thread: Centering square stock in the 4-jaw |
20/10/2017 06:59:37 |
I saw a chap on utube (Â forget who ) put a piece of flat material on each face of the square stock and secured with a strong rubber band and use a dial indicator on inside faces to centre stock Mick |
Thread: Perfecto Hand Shaper - worth keeping? |
06/10/2017 08:52:44 |
Keep it !!! Mick |
Thread: Harold Halls QCTP |
06/10/2017 08:51:22 |
Hi folks, Been thinking for a while about a QCTP,ÂÂ decided to have a bash at Harolds design, I have made a few of H's projects and they have all worked fine for me ( thank you Harold) spent yesterday drilling and tapping 60 holes in toolholders, 4 per holder shown in design but decided to fit 5. All going well so far Mick |
Thread: A bit of humour |
29/09/2017 07:04:39 |
I did particularly like the Duck one 🐓 Mick |
29/09/2017 07:00:34 |
A 2 seater aircraft has crashed into a cemetry, a Police spokesman said this is a tragic incident and so far 300 bodies have been recovered. Mick |
Thread: Retirement |
17/09/2017 22:07:44 |
Harold, I would like to add my thanks for all your endeavours, you have been an inspiration to me and no doubt many others. I have made a lot of your designs and am currently having a bash at your QCTP. Thank you once again and enjoy your well deserved retirement Regards Mick |
Thread: Our Wildlife and Conservation Activieties in Nambia |
30/08/2017 06:10:59 |
Great photos Joe, its a good job there are people like yourself and Gisela helping our wildlife when there are so many intent on destroying these beautiful creatures, respect to you all Mick |
Thread: What's this? |
28/08/2017 16:57:41 |
How about for holding a spokeshave blade for sharpening on an oilstone Mick |
Thread: Slitting saws |
21/08/2017 05:49:20 |
That explains it Robin,thanks. I always use my Adcock & Shipley horizontal for slitting which is belt driven, hadn't thought of gear heads Mick |
20/08/2017 22:08:51 |
Sorry Howard but why not key the saw to arbour? I always do, any jamming of saws/cutters due to too heavy cut the belt will slip preventing any damage,worked okay. I don't understand Mick |
19/08/2017 09:37:27 |
Don't you just love them, had 3 rescue dogs everyone an individual miss them all xxx Mick |
Thread: Slide felt oil wipers-Shaper |
19/08/2017 09:33:52 |
Thanks chaps, think I'll leave as is Mick |
Thread: Milnes Type 'R' Lathe on eBay |
19/08/2017 09:31:33 |
I wonder where all Curly's machines are now, hopefully survived somewhere,great photo Mick |
18/08/2017 18:19:35 |
I have an 8" Boxford shaper,it has none fitted,a lot of shapers do,on the whole does the panel think they are a good idea or not. Not having them fitted means I can see oil being ejected so at least I know that oil is reaching the slides Mick |
Thread: Another scam |
18/08/2017 18:13:15 |
Just had a message on ansaphone apparently from HRMC telling we are about to be sued and to press one to speak to a case worker,was a female message short and sweet. My daughter just had same phone call, tossers!!! Mick |
Thread: metric fine |
06/08/2017 18:16:34 |
How about cutting the bar down short enough to pop in and put a hinged joint to fit the other half to, put the shortened length in, lift up the top half and in she goes. Just needs a tenon on one half and a slot on the other pinned to keep diameter the same throughout it's length Mick |
Thread: Motor rotation |
31/07/2017 21:02:17 |
Thanks John Mick |
31/07/2017 20:41:19 |
Forgive my ignorance chaps but can these inverters be plugged into a normal single phase socket or do they have to be connected to the house mains switchbox ? Mick |
