Slide felt oil wipers-Shaper
Mick Henshall18/08/2017 18:19:35
562 forum posts
34 photos
I have an 8" Boxford shaper,it has none fitted,a lot of shapers do,on the whole does the panel think they are a good idea or not. Not having them fitted means I can see oil being ejected so at least I know that oil is reaching the slides
Mick
not done it yet18/08/2017 22:51:47
7517 forum posts
20 photos
I'll give it a bump. I might consider felts on a shaper to be better for adding lube, not removing (wiping) it as the ways usually seem to be well away from any flying debris.
thaiguzzi19/08/2017 04:08:11
704 forum posts
131 photos
Would'nt bother.
My 8" Boxford has worked hard for years.Oil daily when in use, if all day, oil twice.
They like to drink oil.
Ady119/08/2017 09:16:04
6137 forum posts
893 photos
Recent felt thread.
I got a sheet and would describe it as medium hardness
You can use a leather punch tool to punch neat holes in it
Mick Henshall19/08/2017 09:33:52
562 forum posts
34 photos
Thanks chaps, think I'll leave as is
Mick
IanT19/08/2017 09:49:16
2147 forum posts
222 photos
Mick,
My Acorntools 7" (UK version of Atlas) has both felt and neoprene "wipers" - the felt is on the inside, with the neoprene on the outside. Formed aluminium covers (with oil holes) hold them both in place (although mine are somewhat chewed up). They are fitted to both the ram and the cross-slide. I tend to agree that the ram doesn't attract much swarf (and it also has slide-way oiling points) but the only lubrication on the cross-slide is via the felt oilers. This area also gets a lot of swarf on it, so I think the neoprene wipers are useful here.
They are simple to cut with a sharp knife and as Ady1 says, a leather punch will make the required holes. I drew a CAD model, printed a simple cardboard template and cut/punched the oilers/wipers from that.
I don't know what arrangements your Boxford normally has but if the manufacturer fitted oilers/wipers, then it's probably not a bad idea to maintain them.
IanT
Edited By IanT on 19/08/2017 09:51:51
