Here is a list of all the postings John P has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford ml7 Chuck | ||
06/11/2021 12:52:14 | ||
Have a look on the https://www.chronos.ltd.uk/ site here Soba Chronos Product Code: 145056 and also Chronos Product Code: K11100M . The Soba is probably the better of the two.
John | ||
Thread: Mill table wonky | ||
05/11/2021 22:13:23 | ||
John | ||
05/11/2021 21:14:38 | ||
Posted by
I dont know if you are around but I’m still having significant problems with the table wobbling by a couple of thou, The good news is that turning the table the right way round has ensured squareness and there is very very little play in the horizontal plane, once the gibs are tightened. But there is play in the vertical plane. With the table central, I can quite easily lift it by a couple of thou using my fingers under one end. And if I turn the handwheel it has the same effect. Most slideways are dovetail, so secure a table in the horizontal and vertical plane at the same time. But the Dore Westbury is not, the only securing force from the gibs is in the horizontal plane. I find it difficult to believe that this isn’t accounted for in the design somehow. I am wondering if I am missing shims somewhere or something? if you have any thoughts I’d be glad of them (or indeed anybody else!) Cheers The adjustment should be by shimming under the two flat strips fitted to the underside of the table,it may well be that when you remove them the edges that engage under the slideway strips may have worn ,likewise the underside of those two strips may also be worn .It is fortunate that the design of the Dore westbury these parts can be renewed just by replacing the strips in the same way as when the machine was made providing the sliding surfaces of the table are in good order this should be a straightforward procedure although the shimming may be a tedious operation ,as far as i can remember the strips are imperial sizes. Seeing as you have turned around the table it may have been adjusted for when it was the other way round and just needs some adjustment. John
Edited By John P on 05/11/2021 21:16:15 | ||
Thread: Metric Screwcutting on Super 7B with 127 Tooth gear | ||
04/11/2021 16:14:03 | ||
As a general observation (i.e. I have seen it enough now to be bothered to ask the question), why is it that you produce a metric threading chart that includes pitches that are never used and are entirely non-standard (e.g. 2.25mm, 3.75mm, 1.3mm, 1.1mm)? I have seen it with metric thread dial indicator charts as well. How many imperial threading charts do we see that include 6 1/2 tpi or 15tpi or 9 1/2 tpi? The chart replicates all of the metric pitches in the Myford I suppose if i had missed any of these out someone else The 3.75 came out as i had transposed some gears when setting As a matter of interest my Warco lathe has on its screwcutting chart As i said here , John | ||
04/11/2021 11:15:20 | ||
Posted by Pete Rimmer 02/11/2021 16:36:19 My lathe uses 16DP gears except for the metric set which utilises 127 tooth. They are 32DP. I expect that a Myford 7 would get away with 40DP conversion gears but 32DP would do just as well being ever so slightly finer than 0.8MOD. --------------------------------------------------- The gear chart for the 127/60 gears i find much I nearly made a 20 dp 127 gear but realised quite Anyway the chart is there for you to use if you wish, it John | ||
Thread: Warco HV6 rotary table | ||
01/11/2021 11:38:04 | ||
Posted by SillyOldDuffer 01/11/2021 11:26:17 not by rice-farmers in a shed!
John | ||
01/11/2021 09:27:12 | ||
The problem when using a 127 gear on a Myford 7 changewheel machine
I have gone down this same route using a 0.8 module 127 and 60 tooth Here is the screw cutting chart a horizontal version is in the album John | ||
Thread: Is it possible to machine a lathe more accurate than the one you machine it on? If so, how? | ||
31/10/2021 16:50:21 | ||
Posted by Henry Bainbridge 31/10/2021 14:21:36 Hey! How did you know I don't have a lathe? The pedant in my ------------------------------------------------------------- Before answering most posts on here i generally look back through Getting back "How did you know"
The relevant bit i have put in brackets. Hi there, just posting so I can see classifieds. John | ||
Thread: BCA belt replacement | ||
31/10/2021 15:58:12 | ||
This green heat joint belting 5 mm dia is at its limit here driving John | ||
30/10/2021 11:50:29 | ||
Posted by Michael Gilligan 29/10/2021 21:37:33
Hi Michael, Whilst the OP was just getting enough postings just to look at the classifieds Various respondents have pointed to the early names of pioneers https://www.youtube.com/watch?v=yzMU8rH4PN8 was Jesse Ramsden inventing anything or just I suppose the only thing the early pioneers did was to get out of their I suppose i would say to the OP when you get your lathe and have used it John
29/10/2021 20:31:12 | ||
Posted by Henry Bainbridge 29/10/2021 17:47:16
------------------------------------------------------------- Perhaps a poor choice of words on my part ,but if if you take the Is it possible to machine a lathe more accurate than the one you If you mean "make" as in machine then the answer would be no. As far as being able to make another lathe there is simply not enough machining There is no doubt if the ingenuity of some of these early pioneers of the Perhaps an example of this can be seen in this interview, In the closing question Sir Tom was asked At 96 a lifetime of amazing achievements behind you What do you attribute He responded with "Pure luck" Perhaps getting back to the thread in general if you look at some of the answers John | ||
28/10/2021 21:25:18 | ||
"Is it possible to machine a lathe more accurate than the one you machine it on If so, how?" I suppose the question here is posed incorrectly and perhaps should be. If that is so then it is here is one
This cylindrical grinder was made in just that way ,the cylindrical square here As for the how, ME have had the construction article for the last 7+ years John | ||
Thread: Super 7 stiff feedscrews | ||
28/10/2021 08:26:48 | ||
Hi , Sound as if you are having similar problems to the Myford lathe in this posting https://www.model-engineer.co.uk/forums/postings.asp?th=173467 , all routes lead back to RGD.
The conclusion was on this posting was "An update, Myford suggested I return the screw and nut for appraisal, which I did. They detected tightness and suggested it was borderline on tolerance and sent a replacement "original" Myford screw and nut which I fitted today. The replacement is significantly better but lacks the silky smooth action of the metric screw and nut. I can't get it down to virtually nil backlash either. I am reluctant to concede that it may bed in as I feel it should work out of the box." Perhaps they just stuck the old one back on the shelf for re sale! I don't bother with such things now i just make my own they work every time that way. John Edited By John P on 28/10/2021 08:32:44 | ||
27/10/2021 22:01:25 | ||
Hi Steve, Yes those three holes , it would be as well to assemble the parts as suggested earlier just to check the positioning before drilling the holes in the end of the table as if any of the the existing positioning is off it will lead to an error. (because the ****** person who built the mill) as you had written earlier had obviously got some things wrong like having the table the wrong way round. John | ||
27/10/2021 21:07:21 | ||
Hi Steve, just as a postcript to the previous posting that i made be careful about following the drawings as it appears from the third photo down on your posting at 10:34:11 today that the 3 holes that hold the leadscrew nut may also not be in the correct position , that extra little cast in lug on the XY slide is for that third screw ,as far as i can remember the tapped hole sits more to the left and a little higher in that position.Would be worth checking before drilling any holes. John | ||
27/10/2021 20:32:26 | ||
Posted by Steve 355 27/10/2021 14:07:24 Now I’ve just got to work out how to drill accurate holes in the end of that table. Luckily I have a big pillar drill! The easiest way to do this is to remove the XY slide from the machine, | ||
27/10/2021 13:27:56 | ||
Posted by Steve 355 27/10/2021 10:34:11 Is this statement true? :- It doesn’t matter if the milling table is not square to Yes it is true , except for the last part after i had built my Dore westbury
As it is the 1st photo that you have posted showing the underside of the John Edited By John P on 27/10/2021 13:35:41 | ||
26/10/2021 22:16:32 | ||
If the edge of the table is not parallel to the direction of travel which seems to be what you are saying here, it is not anything to do with the slide way strip that you have shown in the photo with the caliper reading of 2.973" .The guide strip that is screwed to the underside of the table the one the gib strip runs on controls the position of the table ,you would need to check that the guiding edges of this strip are in line with table edge. In any event apart from from a nuisance does not affect the operation of the machine in any way ,for what it is worth you would probably need to replace the strip rather than try to reposition the countersunk holes any distortion to the existing strip is likely to lead to more problems.
John | ||
Thread: The Interesting Video Thread | ||
24/10/2021 10:07:37 | ||
If you have half hour spare watch this video on building a home made lathe. https://www.youtube.com/watch?v=z67A3Myy6XM John | ||
Thread: Wandering mill table | ||
23/10/2021 11:03:26 | ||
That looks as if it is ok as noted previously by Journeyman , have you checked also the gib strip adjustment on the Y axis slide way, try the test with the Y axis lock tightened. John |
