Member postings for noel shelley
Here is a list of all the postings noel shelley has made in our forums. Click on a thread name to jump to the thread.
Thread: Greetings from the North
27/07/2023 14:13:15
Welcome to the party Tim, you will need some form of dividing equipment for your orrery, add it to the list. Good Luck. Noel.
Thread: Why do modern car engines have different types of bolt type heads like Torx etc?
26/07/2023 19:23:20
Martin has it ! BMW gearbox held on by normal bolts - EXCEPT the two at the top, there torx ! Just to F--- You up ! It didn't work, I had a set of torx keys ! JCB turbo doost diaphram, 5point torx security( pin in middle), but WHY ? Noel.
Thread: Wiring 4QD controller for 4 motors.
26/07/2023 15:55:19
If you have the money and space then trojan 105 traction batteries BUT they are 6V or 8V so its 4 or 3 units to give 24V or 2 X 6v for 12v. Noel.
Thread: NVR Issues
26/07/2023 09:33:56
The stop button and emergency stop are a NC contact check this. Many after market NVRs are not of the highest quality or built to industrial standards. If you think the motor is at fault then check both start and run windings for continuity, then run thhe motor (lathe ) for a while and let it warm up. If the motor is OK then it can only be a simple fault. Broken wire, loose screw or terminal, incorrect wiring or a faulty NVR, check all wiring from the plug to the motor. Good Luck, Noel.
Thread: Gear
25/07/2023 17:51:15
Most likely cast iron but it still can be repaired may be by brazing and filing Worth a go ! Noel..
Thread: Is a valve plate viable?
25/07/2023 17:47:31
Commercially it's done all the time, so yes. Sealing might be the only problem normally cast in or press fit then machine the valve seat. I would use 2 seperate seats. Noel.
Thread: Rob Roy blowdown valve?
25/07/2023 17:43:31
It's in the right place, and once you can identify the thread yes ! 5/16" x 32 or 40 TPI ME would be my thought ? Noel.
Thread: Centrifugal switch replacement
25/07/2023 10:22:33
What has actually broken ? The wings on the centre look good. If the anchor for the springs has failed then drilling and tapping the centre and making a new fixing may work. Bear in mind that there are 2 common motor speeds and therefore 2 switches, 2 pole and 4pole. See my earlier comment on positioning and correct operation as this could easily cook the windings if wrong. Newman were good motors it would be a shame to see it burnout for the sake of the start switch. If you know what your doing then Johns idea will work though a push button is safer,It may be cap start so the whole start circuit must be switched, you only need the start windings for less than a second in most cases. Noel.
Thread: Is it possible to use leisure batteries
24/07/2023 17:08:59
Traction batteries would be best but leisure batteries would work ! Noel.
Thread: Back copies of Model Engineer
24/07/2023 12:17:23
Dear Pauline, I would be interested and can collect. I have some from the 80s onwards but the early ones would be nice. I will send a private message. Best wishes Noel.
23/07/2023 12:12:09
As Brian has said try cleaning the contacts with 320 or 400 wet or dry paper folded double in a 1/2" strip. I take it the bit you cannot get off is the pulley ? Very careful use of a gear puller may work. When fitting the centrifugal switch the position of the various parts is critical to it's proper operation = if the start windings stay on for too long then they will soon burn out. Good Luck Noel.
Thread: Unacceptable bodge or not
23/07/2023 11:55:13
Martin .Tap parallel and use loctite or If the job will allow it a bonded seal or Dowty washer will make an air tight seal. Noel
Thread: Do you need an oil change with less than 10,000 miles in 10 years?
21/07/2023 10:25:22
As a schoolboy I bought a 1947 Vauxhall to play with using my pocket money (£3) I soon got it running and would drive it round our large garden - it was one way to stop the nettles growing. This I'm sure had a by pass filter, as do the Cummins V8-300s we use of 1960s vintage. And yes, as Howard has said, in the 60s and 70s an engine would need a rebuild at 5 or 6 thousand hours as opposed to modern engines doing 250000+ miles with ease ! How things have changed, ford 100E with metalled in rods, A and B series engines, 4.108, 4.154 6.354, in the 70s I would nearly always have at least one of these on the bench in bits !
Yes ! change the oil every year, no matter what the milage. Engines fail nowadays due to poor design or electrical issues ! Noel.
Thread: Odd thread size.
20/07/2023 21:40:28
8mm X 1mm is a thread size used in some electrical fittings so not uncommon - Tracy tools do them ! Noel
Thread: How to machine this?
20/07/2023 21:37:43
Andrew has beat me to it ! I would cast them ! Noel.
Thread: Colchester Bantam Mk2 mech control linkage to fwd/stop/rev motor switch
20/07/2023 09:53:43
Hello James, welcome to the forum, I can't help with your problem but I'm sure someone on here will be able to help. Good luck. Noel.
Thread: Old Briggs & Stratton sparks
19/07/2023 00:15:24
If the coil is of the points type there will be a gap both sides between the coil and the laminations ! If it's electronic there will only be a gap on one side. it is switched by the action of the flywheel magnet. To set it up put 2 or 3 sheets of paper between the magnet and the laminations, this will pull the mag onto the flywheel and then do up the 2 small fixing bolts and remove the paper. That will set the air gap. IF electronic you DO NOT need the points - remove them. Do NOT loose the flywheel key ! It is aluminium do not use a steel one ! If the key has even the smallest step in it replace it. Noel.
18/07/2023 11:05:05
Are you sure its 4Hp not 3.5Hp ? The modern ie 80s onwards models had a electronic ignition and NO points. They were interchangeable ! one wire went to ground the other to the stop button/control. I dont think the points version has been available for decades. There were many models the numbers were stamped on the air duct over the head. If you need more info I will find my briggs manual ? Noel.
Edited By noel shelley on 18/07/2023 11:09:49
Thread: Myford oilers
17/07/2023 22:40:33
One point worthy of note is that the oil viscosity will change with temperature. Hot workshop = drips fast , cold workshop = may not drip at all ! Not the oilers fault ! Noel.
Thread: Milling - Squaring An Inside Radius Of A Corner
17/07/2023 12:13:32
The seldom mentioned shaper would do the job ? Noel.
