Tim Riome | 26/07/2023 18:18:09 |
2 forum posts | Good afternoon people, I'm somewhere to the north of Inverness. I've just taken delivery of a Colchester Student to replace an ancient and very tired Myford ML7. I'm also expecting a Harrison Vertical mill to be delivered imminently. No doubt I'll be looking for advice on a plethora of topics so thanks in advance for your patience and knowledge. Tim |
Thor 🇳🇴 | 27/07/2023 07:17:41 |
![]() 1766 forum posts 46 photos | Hi Tim, Welcome to the forum. Congratulations with your Colchester. What are your main iterests? Thor |
Tim Riome | 27/07/2023 07:29:54 |
2 forum posts | Hi Thor. Initially most of the work is going to be making all the necessary and unnecessary tooling to allow enough accuracy to build a couple of projects I have in mind. Ultimately I want to build an orrery. Tim |
Thor 🇳🇴 | 27/07/2023 09:07:27 |
![]() 1766 forum posts 46 photos | Hi Tim, An orrery sounds like a fairly complex project, good luck. I have only made model steam engines. Thor |
Howard Lewis | 27/07/2023 11:51:15 |
7227 forum posts 21 photos | Welcome to the Forum. An orrery will be quite a project. You'll become quite good at gear cutting! Howard |
Oldiron | 27/07/2023 13:27:30 |
1193 forum posts 59 photos | Posted by Thor 🇳🇴 on 27/07/2023 09:07:27:
Hi Tim, An orrery sounds like a fairly complex project, good luck.>>>> I have only made model steam engines.<<<< Thor Welcome Tim. Thor, that is quite an achievment on its own. regards |
noel shelley | 27/07/2023 14:13:15 |
2308 forum posts 33 photos | Welcome to the party Tim, you will need some form of dividing equipment for your orrery, add it to the list. Good Luck. Noel. |
Harry Wilkes | 27/07/2023 15:53:33 |
![]() 1613 forum posts 72 photos | Welcome to the forum H |
