Member postings for HomeUse
Here is a list of all the postings HomeUse has made in our forums. Click on a thread name to jump to the thread.
Thread: 25 year Special
09/05/2015 18:04:05
Sorry Jason - Thought you were referring to my post one before gordonslaugh
09/05/2015 17:53:22
Jason - Click on the block above the picture where it says “Special Issue” - Thats where all the details about the publication are - I Know it £4.99 plus Post which makes it a total of £6.98
09/05/2015 13:52:45
Don’t get me wrong I’m not dissatisfied with what is included but more disappointed that what I thought was included was not - I still say that the advert is very misleading
09/05/2015 13:34:49
If you go to the home page and click on the heading of the advert for the mag you will get the full ? Accurate ? details
09/05/2015 12:28:42
How about this “copy and paste” from the advert
You can pre-order 25 Years of MEW HERE (note that the preview info was written before publication, the sample pages below give an accurate picture of the content).
Accurate Picture !!! NOT SUBJECT TO CHANGE - indecision
09/05/2015 10:45:58
I was not expecting 10 new articles from contributors but was expecting as stated on the front cover under the separation line of Harold Hall’s article
“ myhobbystore inside this issue Full Details and Plans for Ten Classic Designs (which included thumprints of two hobby store plans) “
frown
09/05/2015 09:21:02
Hi Neil - Yes I agree but how many of those are by myhobbystore .
The advert indicates that the store has ten classic designs and plans INSIDE THIS ISSUE (pics. of the plans are overlapping the “ inside this issue” block) which seems to refer to the said plans.
The 10 articles you refer to are by contributors in past magazines of which I have copies and have in fact made some of the items.
Still angry at having bought what turn out to be mainly copies of my collection
08/05/2015 17:34:06
This is a copy of the review I posted on the MyHobby Store review site after receiving my copy of the 25 years magazine (ordered direct from them)
As you may conclude I am not overly happy with the way the product was advertised (Misrepresentation comes to mind) crook
[On the cover it shows “Details and Plans for ten classic designs” INSIDE THIS ISSUE
Don’t get misled all that is inside is lists of plans available “at a purchase price” from the store - details of these plans can be obtained by visiting there online shop.
I was expecting copies of plans/and details to be included within the publication ]
I am expecting my review will be posted out of the magazine site - also possibly this post
Thread: 3 1/2" Gauge Discussion Group
03/04/2015 08:27:41
Hi - Just for interest there is a 3.5inch group on Facebook 03 1/2” Gauge Enthusiasts Group.. lots of comments/pics. and info.
Thread: Parting Off Tool Made From 1/64" Slitting Saw
27/03/2015 08:49:43
Made one years ago from pieces of broken blade - got the idea from ME Mag in about 1960 ish wink
Thread: Using 3D prints for casting
18/02/2015 09:45:39
I have been experimenting with direct extrusion of wax but the problems i have encountered have been trying to cool (solidify) the wax quick enough after the hothead so as to retain its shape and not “sag” - At the moment the extruder is hand worked as the full printer is not completed. - A fellow experimenter is developing the idea of producing 3d printed (plastic) moulds into which wax can be injected for lost wax casting - this can become complicated if there are a lot of undercuts.
Thread: Have you ever considered getting a 3D printer?
18/02/2015 09:01:25
Yes - Am in the progress of building one from scratch - using redundant computer, scanner and printer parts for power supply, motors and linear drives. The basic design thoughts originated in the U.S. but other than power supply are the same over here (U.K.). The hot head is machined from brass and the heating element is available commercially on ebay as is all the driver boards - Will post more details later
Thread: Tiny Vertical Engine with Reverse
15/02/2015 10:38:04
Now that is what I wood call a good “Bog Standard” designembarrassed
Edited By HomeUse on 15/02/2015 10:38:34
Thread: Hep with steam chest
08/02/2015 09:44:56
img_0010_1.jpgNeil’s calculations worked for me on my scratch built 044 (Johnson design) Loco (Did get a bit of help from LBSC designs) All haters home made and cast iron castings by a local foundry.
Thread: Special bolts for when you make a mistake
08/02/2015 09:33:35
Hav got a few double drilled holes - the problem is which leg do I screw in first ( The wrong one or the right one )secret
Thread: Poblems saving IGS Files inTurbocad Pro Platinum
05/02/2015 16:54:11
Hi - One of the problems with Turbocad is the if you us a Professional programme to draw the original and then update to Platinum of a higher number (more recent issue), then it is more than likely that the new programme will not read all the old machine instructions (code) as the Platinum usually has less inbuilt functions ( one of which is loading, reading and saving certain 3D formats) - Ive had similar problems.
[ Turbocad user for well over 20 years - since Issue 3 Professional ]
Thread: Casting a Wright Broithers Model B Crankcase
03/02/2015 14:39:58
Thats a lot of work but it looks like a good clean casting - I did fast forward a bit in places - Bit to involved for my back yard setup crook
Thread: rivetting
31/01/2015 12:58:42
I’ve had no problems with 28swg brass using a 1.6mm (1/16&rdquo standard drill - Usually I clamp between two heavier gauge sheets, The top one being the marked out pattern (usually predrilled if working freehand on the bench drill) and the bottom sheet (usually aluminium) to support the drill on its run out.
Thread: Waterproofing a Roof?
18/01/2015 09:37:51
I think you are in the hands of the Local Authority as to what can be done - Yes there are numerous Tar and or Silicon based liquid preparations that are readily available and applied to the outer face of the sheeting to a water repellent surface, but this does not stop any condensation drips from forming. One way to stop the condensation is to spray the underside of the roof with an expanding foam compound (Unfortunately costly and specialist applied), again many firms regularly advertise this product.
How about considering a good quality protection (waterproof) tailor made if required to fit over the car when the inclement weather is about thinking
Thread: Editors Deliberate Mistakes
17/01/2015 14:20:16
Think J S is considering bringing back the Stocks and Pillory (Flog the lot)
