Band saw
anthony daborn | 19/09/2014 14:00:52 |
8 forum posts | Help! is there a simple plug in variable speed device that I can purchase that will reduce the speed of my floor standing band saw so that I can then cut sheet metals. I have the right saw blades but the wrong speed. I tried to find a bench top metal cutting bandsaw without any luck |
Les Jones 1 | 19/09/2014 14:38:34 |
2292 forum posts 159 photos | Hi Anthony, Les. |
Peter Tucker | 19/09/2014 18:56:09 |
185 forum posts | Hi Anthony, My father in law fixed a worm drive between the motor and pulley on his wood cutting band saw for cutting steel. Hope this helps. Peter. |
Mike Poole | 19/09/2014 22:11:04 |
![]() 3676 forum posts 82 photos | To cut steel and wood on the same bandsaw you wil need around a 10:1 reduction, this is not really a suitable reduction for an electrical solution if you would like some power to cut with. A mechanical solution will be the most satisfactory, either a gear redution unit or a two stage belt and pulley setup. Mike |
Neil Wyatt | 20/09/2014 19:58:44 |
![]() 19226 forum posts 749 photos 86 articles | Here's a solution for someone who's happier working wood than metal. Neil |
Speedy Builder5 | 20/09/2014 20:22:03 |
2878 forum posts 248 photos | Interesting post from Neil. Also see old post 'Bandsaw speed control' But it doesn't answer your question easily. I wonder if any of our electrical boffins could show us how to use a washing machine motor which has a speed sensor built into it to produce variable speed 240V motors. |
Speedy Builder5 | 20/09/2014 20:49:39 |
2878 forum posts 248 photos | Thinking on from washing machines. Modern machines have very small multi groove pulleys on the motor. My bandsaw has a 'V' motor pulley of about 2". If that was replaced with a 3/4" multigroove, it would reduce the 800 f/min to about 350 f/min. BUT we are looking for 100 f/min or less I believe. My motor is 2800 rpm, but a 1450 rpm motor would just about get you there. If you do as Neil says and search Using old washing machine motors, there is a wash M/c motor controller for DIY for about £40. We need more input from our Boffins. BobH |
anthony daborn | 29/09/2014 11:23:51 |
8 forum posts | Thank you all. Some enlightening observations there. I do not have the space for a speed reduction box, and whilst the washing machine pulley is a possibility as I was not aware of the pulley size, I wonder about the torque though? As time is of the essence I may just go for replacing my 1ph. 1250rpm. 850w induction motor with a new 3ph job with inverter and speed control. How is it that none of many machine tool suppliers have thought of a bench mounted metal cutting band saw. after all it surely is only a motor and pulley change. Subject to torque issues of course. Thanks for the advice, will let you all know my chosen route soon .Off to the oncologist now. Cheers Tony |
Les Jones 1 | 29/09/2014 12:02:44 |
oldvelo | 30/09/2014 04:09:41 |
297 forum posts 56 photos | Hi On the band saw I rebuilt with two drive motors one for wood hp 1425 rpm driving a counter shaft and one for metal 3/4 hp 1425 rpm driving a 18 to 1 worm gearbox that drives the counter shaft with "Poly Vee" belts all round Remove the belt from the worm gearbox for wood and swap motor plugs. Motor RPM Metal Cutting Motor 1 Dia mm G'Box Dia Wood & Composites Motor 2 Dia mm C\Shaft Dia Metal Metres Min Wood Metres Min Sorry about the Layout Just cut and pasted from an XLS Spreadsheet Used to find optimum ratios and pulley sizes May be useful Still toying with using a 1.5 hp DC motor and KB Electronics Controller and two speed pulleys. Though two speed may not be needed as KB quotes up to 50 to 1 speed control and up to 120% max motor speed. And 0 to 30% min speed on trimpot adjustment of controller. Not the cheapest option DC drives. Mine is a Totally Biased opinion as a "DC Drive" and "Poly Vee" belt transmission addict. Eric
Edited By oldvelo on 30/09/2014 04:10:54 |
Les Jones 1 | 30/09/2014 08:18:57 |
2292 forum posts 159 photos | Hi Eric, Les. |
anthony daborn | 04/10/2014 17:58:43 |
8 forum posts | Dear Les ,thank's for your contribution ,I am inclined now to follow your solution of the 6x4 bandsaw idea although it would be a bit large. Space restrictions and only occasional use of the wood bandsaw might make me retire it so that I have the extra room. Thinking to do. Thanks again Tony |
