d13 camlock pins
richard heard11/09/2014 20:46:22
7 forum posts
I am having trouble finding d 13 camlock pins 7/16 unf for older type back plates and wandered if I could make some myself and what material I should use has any one any thoughts on this the major size of these pins is 9/16" thank you in advance RHeard.
Neil Wyatt11/09/2014 20:56:54
19226 forum posts
749 photos
86 articles
Welcome to the forum, Richard. take a look at this thread:
Tony Ray11/09/2014 22:54:26
238 forum posts
47 photos
Richard,
They are available from Rotagrip but will set you back £56. Could you change the backplate to a metric one? They usually come withe the pins Eg Warco sell them.
Nick_G11/09/2014 23:48:37
1808 forum posts
744 photos
Thread on these is 10 x 1 so perhaps of no value to you. :- **LINK**
But you may be able to cut the threads off, tap and stud them to your required thread.
Nick
Edited By Nick_G on 11/09/2014 23:51:36
Muzzer12/09/2014 02:46:11
2904 forum posts
448 photos
To answer the OP's question, I'd suggest you use some form of carbon steel that will allow you to harden them once you have made them. The dimensions are given in the drawings but there is no mention of material or hardness. I can copy you the original document if you are interested (PM me).
Apart from needing to set them up carefully and machine them accurately, the basic shapes involved are fairly straightforward. I only made up the mating parts but I imagine a rotary table in the milling machine would be the way to go if you want to make the studs yourself.
I'm sure I've seen these on sale in a few places but not at a particularly appealing price.
Murray
Tony Ray12/09/2014 12:38:35
238 forum posts
47 photos
Richard,
Try this company inthe USA
They have been recommended on the Practical Machinist forum
Do check that they are imperial though.
I have used their enquiry service before and received a reply in two or three days that they were OK to ship to the UK and the cost of shipping was very reasonable. At that price you might consider a second set as it's not likely to push up the shipping costs that much.
richard heard18/09/2014 16:42:48
7 forum posts
hi thank you all for your input / I think maybe if I re drilled the cam pin holes in between the originals @ re tapped 10mmx1 and used metric pins from myford it could be the cheapest option Richard
