Here is a list of all the postings richard heard has made in our forums. Click on a thread name to jump to the thread.
Thread: colchester master mk 2 cross slide @compound slide locks |
18/11/2016 19:52:22 |
has anyone fitted locks on the Colchester master mk 2 cross and compound slide,s any info would be appreciated thank you in advance for any info regards Richard. |
Thread: bridgeport mill table feed wiring diagram with erskin pd/1114/01/b control unit |
18/12/2015 10:14:12 |
Hi thank you all for your input I have now checked the wiring and all seems to be o/k other than the erskin board which as not got any voltage across n/o 6@7 which should be variable between low volts to 100 volts and when power is on r/6 @ r/7 resistors get hot within 20 seconds or so to hot to touch so problem must be on the board thank you all again regards Richard |
07/12/2015 21:56:09 |
hi emgee I have checked continuity of the overload and solderd 3 very loose dry joints on the terminal connection board there is now something happening as a resistor is heating up it is green and marked w22-100 r which makes me feel there is a wire on wrong from the control out to the switches regards richard |
07/12/2015 20:55:04 |
hi I am hoping someone can help me. I have a Bridgeport mill serial n/o445750388 with a erskin table feed control n/o pd/1114/01/b which is not working has someone got a wiring diagram for this unit up to the micro switches and pot as it looks as if my wiring has been got at and could be all mixed up kind regards to all richard |
Thread: d13 camlock pins |
18/09/2014 16:42:48 |
hi thank you all for your input / I think maybe if I re drilled the cam pin holes in between the originals @ re tapped 10mmx1 and used metric pins from myford it could be the cheapest option Richard |
11/09/2014 20:46:22 |
I am having trouble finding d 13 camlock pins 7/16 unf for older type back plates and wandered if I could make some myself and what material I should use has any one any thoughts on this the major size of these pins is 9/16" thank you in advance RHeard. |
Thread: info on soba 6" rotary table |
26/02/2014 10:29:09 |
I am thinking of buying a soba 6" rotary table does anyone know of any problems with this table hoping someone can help thank you RHeard. |
