Oompa Lumpa | 09/08/2014 18:34:22 |
888 forum posts 36 photos | So, with the ongoing restoration of my Drill Press it is time to order the bearings. The roller bearings are pretty straightforward but I have come to a screaming halt with the thrust bearing. I usually use Simply Bearings to get my bearings from but I have been going round in circles (?) for a little while looking for a replacement. I was thinking maybe a spherical thrust bearing may be an alternative but that isn't going to work so if anyone could give me some suggestions as to a supplier of one of these. It is a Roller Thrust Bearing, 1.5" in diameter, 5/8" thick and a 3/4" hole in the centre: graham. |
Enough! | 09/08/2014 18:47:14 |
1719 forum posts 1 photos | Don't know how far afield you want to go, Graham, but I've always found VXB to have a wide range of bearings at reasonable prices and shipping rates. |
Keith Long | 09/08/2014 19:00:32 |
883 forum posts 11 photos | Unless I'm missing something somewhere that looks like a BALL thrust bearing. How tight are the meaurements that you gave, because Simply bearings have a ball thrust coming up with 3/4" bore, 5/8" thick but with a 1.531" od - which seems like a funny number to me (1 17/32" Keith |
Bazyle | 09/08/2014 19:47:04 |
![]() 6956 forum posts 229 photos | No answer to your problem but I like the look of your posts on the drill restoration. Can you repost it all in its own thread please as it will get lost in the WDYDT thread. My Meddings 'restoration' only consists of removing the cement and glue. "Boss! Where shall I put the glue pot while I drill this bag of cement?" |
Boiler Bri | 09/08/2014 20:11:43 |
![]() 856 forum posts 212 photos | Yep defiantly a ball thrust bearing. Readily available at most bearings suppliers, Wyco, bearing services etc.
Bri |
Oompa Lumpa | 09/08/2014 20:39:49 |
888 forum posts 36 photos | Posted by Keith Long on 09/08/2014 19:00:32:
Unless I'm missing something somewhere that looks like a BALL thrust bearing. How tight are the meaurements that you gave, because Simply bearings have a ball thrust coming up with 3/4" bore, 5/8" thick but with a 1.531" od - which seems like a funny number to me (1 17/32" Keith Roller bearing/Ball bearing - lost a bit in translation there, sorry. But that is actually the exact size I am looking for, I agree 1 17/32" IS odd. My problem is, I can't find it. If you could give me a link I would be grateful. Thanks. GOT IT! Thanks everyone. graham. Edited By Oompa Lumpa on 09/08/2014 20:53:10 |
Keith Long | 09/08/2014 20:46:25 |
883 forum posts 11 photos | Hi Graham Try this link hopefully it should take you to the bearing. The code number I'm getting up is showing as an LT3/4 Imperial Thrust Bearing. Got the price wrong it's actually listed as £7.60 + vat. Good luck with the search. Keith |
Oompa Lumpa | 09/08/2014 21:04:53 |
888 forum posts 36 photos | Posted by Bazyle on 09/08/2014 19:47:04:
No answer to your problem but I like the look of your posts on the drill restoration. Can you repost it all in its own thread please as it will get lost in the WDYDT thread. My Meddings 'restoration' only consists of removing the cement and glue. "Boss! Where shall I put the glue pot while I drill this bag of cement?" I will try to collate the various posts and put the images in some sort of order. I spent an hour today with the main head. I have had it soaking in a five gallon drum of cellulose thinners. It was a very messy job, it is back soaking. Trying to get fifty years of grease dissolved. graham. |
Oompa Lumpa | 09/08/2014 21:48:37 |
888 forum posts 36 photos | So while we are all still here, thinking ahead I am going to have a bit of a problem with the motor and the pulley. The pulley has a 5/8" hole in it and the nearest is a 16mm shaft. Shall I just shim it out a bit, or replace the pulley? I am going to be using a Variable Frequency drive on the machine so I want it to be as smooth as possible. graham. |
roy entwistle | 10/08/2014 09:26:37 |
1716 forum posts | Graham Could you open the hole in the pulley and then put a sleeve in it ? Roy |
Bob Brown 1 | 10/08/2014 10:10:27 |
![]() 1022 forum posts 127 photos | 5/8" = 15.875mm so if motor shaft is 16mm just open up the hole by 0.125mm Thrust bearings are not that close on fit to the shaft or housing as they are designed to take a thrust load. Edited By Bob Brown 1 on 10/08/2014 10:12:11 Edited By Bob Brown 1 on 10/08/2014 10:12:53 |
Oompa Lumpa | 10/08/2014 13:09:15 |
888 forum posts 36 photos | Roy and Bob, thank you for wasting your time on an idiot such as myself. For whatever reason, I had convinced myself that 16mm was smaller than 5/8". I have no idea. Last week I had convinced myself that 3/4" was only a few thou short of 18mm. Which is totally untrue. I am going to put it down to age and the fact I have to deal with some customers who are as thick as chocks. After a while some of the stupidity wears off them and onto me and I am probably well infected by now! graham. |
Nicholas Farr | 10/08/2014 14:22:01 |
![]() 3988 forum posts 1799 photos | Hi, you will find that one of the bores of the bearing rings is a close fit to the size of the shaft/spindle and the other one is slightly larger, the slightly larger one being clear of the rotating shaft/spindle. Regards Nick. |
