Nick_G | 21/07/2014 17:58:44 |
![]() 1808 forum posts 744 photos | . I have a Boxford lathe and the drive belt looks to have seen better days (bit like me. I have seen various mentions that 'linked belts' are good performers and a worthwhile upgrade to some machines. - So would such a belt (see pic) be suitable for my Boxford or would I also need to change the pulley's.? The existing belt is a 10mm width V belt. i.e. this type of belt (10mm Z section) :- On this :-
Cheers, Nick Edited By Nick_G on 21/07/2014 18:00:45 |
Bob Brown 1 | 21/07/2014 18:23:38 |
![]() 1022 forum posts 127 photos | The belt would have been marked on the outside if that is no longer visible it is probably easier to take the belt off and take it along to a local belt supplier who should be able to sort out a replacement. Or give Boxford a ring on 01422 324810 see http://www.boxford-software.com/spares/X10Guard.html and if I'm correct the belt is a SPZ-737, "Z" section If I had the option which I don't I would replace the linked belt on my Boxford AUD with a "normal" one but it has to be split to fit. Edited By Bob Brown 1 on 21/07/2014 18:28:36 Edited By Bob Brown 1 on 21/07/2014 18:42:33 Edited By Bob Brown 1 on 21/07/2014 18:48:58 |
Nick_G | 21/07/2014 21:32:42 |
![]() 1808 forum posts 744 photos | . Thanks for the reply Bob. I do know the size of the existing belt but I was wondering if the linked belt may be an improvement in decreased vibration.
Regards, Nick |
Bob Brown 1 | 21/07/2014 22:10:00 |
![]() 1022 forum posts 127 photos | You could try a new standard one as they are not expensive as a starting point, I can see no reason for a linked belt to reduce vibration but again nothing ventured gained. |
Roderick Jenkins | 21/07/2014 22:13:58 |
![]() 2376 forum posts 800 photos | I think the linked belts are more flexible, so will help to absorb any vibration. I remember reading that Tubal Cain replaced the secondary drive belt on his Myford Super 7 with a Brammer link belt and considered it an improvement. Cheers, Rod |
