clivel | 09/07/2014 23:50:25 |
344 forum posts 17 photos | I have been building a Don Young #1 Railmotor for some time now, unfortunately space limitations and a little Unimat lathe have very much restricted me to working on smaller items: lubricators, smoke box door handles, etc. However, the recent purchase of a 10" Logan lathe, followed by a house move that will give me half a double garage, just as soon as I have the pile of boxes still stored there unpacked, means that these restrictions will no longer apply. So in the meantime I have been accumulating the necessary material to make a start on the frames, which is when I noticed two handwritten amendments to the mainframe on sheet 1 of the drawings. Unfortunately these changes are more or less illegible.
If anyone could shed some light on these changes, it would be appreciated, Thanks, Clive
Ady1 | 10/07/2014 09:57:20 |
![]() 6137 forum posts 893 photos | There's a few threads on this model The name varies as well.... I quote I think the problem was all the articles were titled 'simple 040 locomotive' (In ME) rather than railmotor, I fell into the same trap many years ago...... Hope that helps a bit |
Ady1 | 10/07/2014 10:30:23 |
![]() 6137 forum posts 893 photos | I've sussed it for searches. You must look for Rail-Motor in the online index The hyphen is an essential part of the search computers... tsk tsk tsk
Edited By Ady1 on 10/07/2014 10:33:19 |
clivel | 10/07/2014 22:58:16 |
344 forum posts 17 photos | Ady, Thanks for the links to the threads and the online ME index, unfortunately it seems as if the drawing changes were made some time after the articles were published in ME. I just noticed that Sheet 6 which details the oil pump drive linkage has a handwritten note: "See sheet 1 Note 1", which makes me wonder if the stretcher doesn't perhaps foul the oil pump drive? Clive
Edited By clivel on 10/07/2014 22:59:00 |
julian atkins | 11/07/2014 07:00:35 |
![]() 1285 forum posts 353 photos | hi clive, i am afraid i cant throw any light on the handwritten notes on your drawings. there are no such notes on the drawings supplied by don young himself. i do not recall any problems with either of the stretchers to which you refer. however there is a problem with the vertical stretcher (that in due course the axlepump body is fixed to) at the front bottom corner of the frames which shares the same bolt holes as 3 of the cylinder bolts. you need to think about how you will tighten up these bolts as designed. cheers, julian |
clivel | 14/07/2014 18:01:10 |
344 forum posts 17 photos | Hi Julian, Thanks for the response and the heads-up on the axle pump stretcher. Do you have any suggestions as to how best to handle the cylinder/stretcher bolts? Over the weekend I popped into a local library which holds a collection of ME going back to 1928. I browsed through the Don Young articles published subsequent to the Railmotor series and found a comment in the "Elaine" series, 17 July 1970, page 694, where he writes in reference to Railmotor 1: "Then my first drawing error came to light. The frame stay immediately behind the cylinders would have fouled the lubricator drive ...... " He then describes how he inverted the stay and slightly altered the lubricator drive. From the cryptic note on the Reeves drawings it would seem that they recommend leaving out the stay entirely. I did contact Reeves to see if they could shed some light regarding the notes on the drawings supplied by them, unfortunately I have yet to receive any sort of reply, Thanks, Clive |
Ady1 | 14/07/2014 21:41:08 |
![]() 6137 forum posts 893 photos | Had another dig with "Rail Motor" Found your drawing error in 3397 ME 3404 p1054 Which reminds There's a pic of the lubricator drive ME no 3405 p1106 Pic of the cyl ports being milled ME3408 p20 ME3433 p63 Don Y0ung’s N0. 1 Rail Motor seen on its first outing ME3444 p642 The Rail Motor ME 3446 has a pic of Don Young steaming his R-M Page746 ME 3478 P1060 The bottom straps project a considerable dis- after replacing a-t least one sheared ME 3543 p800 A 5 in. GAUGE “RAIL-MOTOR” The design of the locomotive is basically very |
Ady1 | 14/07/2014 22:03:41 |
![]() 6137 forum posts 893 photos | ME3525 p1139 In more
Ady1 | 14/07/2014 22:08:28 |
![]() 6137 forum posts 893 photos | ME 4374 p403 Guildford MES Andrew Hook: |
julian atkins | 14/07/2014 22:46:25 |
![]() 1285 forum posts 353 photos | i started my own Railmotor at the age of 16, 31 years ago cycling to don's home at adgestone to collect the drawings and castings. i decided on separate holes for the front corner frame stretcher separate from the cylinder bolt holes. i dont recall any problems re the other vertical stretcher in front of the front axle, though to be honest it's a long time ago, and in any event i worked out a different drive arrangement for the mechanical lubricator from the axle pump. it is the only loco ive built fitted with a mechanical lubricator, all others having hydrostatic sight feed lubricators. i recall re-arranging the smokebox innards so only one steam stand pipe which the mechanical lubricator to feed into before branching off underneath to the cylinders. i had don's original Railmotor in my workshop for some time after his untimely death. it differed quite a bit from his drawings! i dont think that Adey's research through the archives is of much consequence to builders who follow the original drawings. i also had don's K1/1 in my workshop after his death. don told me privately (as he did to all builders who bought drawings from him direct) not to open out the cylinders for the No.1 version above the size specified for No.2. hence my misgivings over the EMMA VICTORIA currently described in ME which advocates the same size cylinder castings but opened out to 1 3/16" bore, yet has a smaller boiler. cheers, julian |
clivel | 15/07/2014 18:32:28 |
344 forum posts 17 photos | I am pleased to say that Reeves responded. The first note should be: This stretcher fouls lubricator drive. Suggest omit as frames well stayed without this stay. The second note should be: Easier to fit s/box if this dimension reduced to 1/4". Ady, Thanks for the very useful references. I think that another visit to the library is called for. Julian, Thanks for the valuable information, I recall you mentioning the size of the cylinder bore in another thread, as a result of which I had already made a note to this effect on my own copies of the drawings. Thanks,
