Cheapskate
Milling cutter tray
donkey03/07/2014 17:03:21
85 forum posts
5 photos
image.jpgI have a real milling cutter tray but I found these ice stick trays at two for a pound at poundland (other pound shops are available. )thought you may like to know.
Edited By donkey on 03/07/2014 17:04:14
Edited By JasonB on 03/07/2014 17:12:39
donkey03/07/2014 17:05:37
85 forum posts
5 photos
Darn it upside down.
Bri
Edited By JasonB on 03/07/2014 17:13:03
Bazyle03/07/2014 17:18:32
6956 forum posts
229 photos
I thought you were going to recommend a magnet holding them in when downsideup smile p
Neil Wyatt03/07/2014 17:22:09
19226 forum posts
749 photos
86 articles
If it holds them in when upside down, it's a brilliant deal for a quid.
My best recent bargain purchase was a full £5 - it's one of those little white LED battery lamps, but this one has a PIR and an ambient light detector, so it's off all the time, except when I enter or leave my workshop with the lights out. I kept meaning to make something like this, but £5 is cheaper than buying the PIR alone!
frank brown03/07/2014 18:58:36
436 forum posts
5 photos
Hi Donkey I'm off to Poundland ASAP, don't even know where the local one is, might send SWMBO as she likes that sort of operation.
On this sort of thing, about 37 years ago I bought a cheap socket set which was (is still) OK, but the blow molded insert looked kind of flimsy so I took it out and filled the back with a lot of wet plaster with added foam for lightness. The liner is still like new. Now a days the boxes seem to be two plastic mouldings glued together, with moulded catches that break off .
Frank
Bob Brown 103/07/2014 19:20:50
1022 forum posts
127 photos
Slightly more expensive but has solar cells **LINK** fitted by front door but saved fitting a cable, switch and PIR.
donkey03/07/2014 19:54:24
85 forum posts
5 photos
Bazyle
for a magnet to hold chuck keys etc to machines I use a magnet from the kitchen department of idea they are really strong covered in plastic and best of all cost just £1.99 each I have them on every tool to hold the correct spanner or chuck keys etc. many uses.
bri
donkey18/07/2014 16:23:19
85 forum posts
5 photos
The magnets are from IKEA not idea. Fat fingers
brian
