rebekah anderson | 29/06/2014 14:31:58 |
135 forum posts |
Hiya, im looking for an 18tooth tufnol tumbler gear. I've seen some on eBay but wondered if there are better deals as I need 2 of them.
JohnF | 29/06/2014 19:13:21 |
![]() 1243 forum posts 202 photos | Hi I looked on EBay. and they are less expensive on the Myford site see http://www.myford.co.uk/acatalog/Myford_Gears.html Looks like the eBay ones are loaded to give free postage ! Regards John |
John Stevenson | 29/06/2014 19:37:20 |
![]() 5068 forum posts 3 photos | Those red ones off Ebay are the wrong type of material, you might as well use putty.
Are those 7/16" bore Becky ? |
stan pearson 1 | 29/06/2014 23:00:36 |
![]() 135 forum posts 2 photos | Hi Rebekah John is correct buy the ones from Myford they are cheaper and fit no problems, I have just fitted 2 new ones to my Super7, Regards Stan |
Swarf, Mostly! | 30/06/2014 10:18:53 |
753 forum posts 80 photos | Hi there, Rebekah, Are you sure you need two-off? The parts list on the Mytholmroyd-Myford web-site specifies one-off 18 tooth, 75/1241 and one-off 20 tooth, 75/1242, (per lathe). Best regards, Swarf, Mostly!
John Stevenson | 30/06/2014 10:35:00 |
![]() 5068 forum posts 3 photos | Swarf, Only Becky can answer this one as her lathe is a much modified ML4 and I dare say nothing is standard.
rebekah anderson | 30/06/2014 12:37:28 |
135 forum posts | Good question. i didn't consider there to be a difference. I only kept one. Oh crapola. guess I'll find out. Cheers guys becky
Swarf, Mostly! | 30/06/2014 14:56:29 |
753 forum posts 80 photos | Hi there, Rebekah & JS, Oops!!! My mistake!!! The part numbers I quoted in my earlier post are for the steel gears that the Tufnol ones replace. The part numbers Mytholmroyd-Myford quote for the Tufnol gears are: A1781, (B36, Reference Number 498), 18 teeth, £17.68 + VAT., A1782, (B35, Reference Number 499), 20 teeth, £17.68 + VAT., All the tumbler reverse set-ups I have encountered use two non-identical gears (idlers). Regarding your point, John, I guess that can only be resolved by a comparison of the gear centre distances and spindle diameters on the ML4 and ML7. Best regards, Swarf, Mostly!
John McNamara | 30/06/2014 15:35:05 |
![]() 1377 forum posts 133 photos | My old (Very) change gear Colchester had different size gears.... Is it not to do with allowing them to clear the spindle gear when being rotated? Regards |
Neil Wyatt | 30/06/2014 18:01:26 |
![]() 19226 forum posts 749 photos 86 articles | > Is it not to do with allowing them to clear the spindle gear when being rotated? probably, on my mini-lathe the large gear is in permanent mesh and the smaller gear is 'free'. Neil
John Stevenson | 30/06/2014 18:53:51 |
![]() 5068 forum posts 3 photos | Swarf, Be hard to say what they are because if I remember the thread correctly Beckys machine as posted had been seriously updated so might have a ML4 tumbler on it or a ML7 tumbler on it.
This is Becky's lathe but the tumbler isn't that clear.
With the alloy extension piece it looks more like a pimped up ML4 as opposed to the stubby acorn ML7.
Would be nice to know what bore they are. |
Bubble | 01/07/2014 13:05:35 |
75 forum posts 6 photos | Hello all Tony Griffiths' site has a photo of an ML4 fitted with an ML7 tumbler reverse, including the reverse lever/gear carrier. Jim |
