Martin McDonald | 15/06/2014 11:51:15 |
4 forum posts | At long last, I'm starting to assemble a mountain of bits and pieces, made over far too many years, into a 2" scale 'Minnie' traction engine. The boiler has an external, raised, 1/8" copper thickening plate (unmachined after being silver soldered to the boiler barrel) for the mounting of the cylinder and I would welcome views on the best way of sealing the joint between the pad and the machined curved surface of the underside of the cylinder. At present, I am thinking of the following 'sandwich' :-
The boiler has already been tested hydraulically after fitting plugs into all the screw holes in the raised pad. I would be most grateful for advice on sealing this important joint in preparation for a steam test. Many thanks, Martin McDonald
JasonB | 15/06/2014 12:46:38 |
![]() 25215 forum posts 3105 photos 1 articles | The Graphite Foliac is the popular choice, you could go down to 1/64 jointing but that will really depend on what you allowed for when machining the underside of the cylinder saddle. J |
Martin McDonald | 15/06/2014 21:34:02 |
4 forum posts | Thanks for that, Jason.I presume that you would agree with anointing with Foliac both under and over the gasket itself, as I described. Many thanks, Martin McDonald |
JasonB | 16/06/2014 07:01:38 |
![]() 25215 forum posts 3105 photos 1 articles | yes both sides |
RRMBK | 25/02/2017 15:07:04 |
159 forum posts 18 photos | I am looking to seal the same joint on a 3" Burrell which doesn't have the raised pad . I have boss white on stock. is this suitable instead of foliac ? |
Balljoint | 25/02/2017 19:51:44 |
39 forum posts 12 photos | I tried boss white on my 2" Fowler, but it didnt work. Redid the joint with Steamseal, graphite Foliac , from the local Plumb Centre, no problems |
JasonB | 25/02/2017 19:55:06 |
![]() 25215 forum posts 3105 photos 1 articles | I think boss white is only good for 200degC and about 150psi so you will be pushing things, Steamseal as they now seem to call the Graphite Foliac is rated to 600deg C and something over 1000psi |
Chris Gunn | 25/02/2017 19:56:03 |
459 forum posts 28 photos | + 1 for Foliac on all sides Chris Gunn |
TREVOR WILSON | 28/04/2020 08:40:57 |
9 forum posts 7 photos | can anyone suggest a supplier for AFM 30 gasket material for my 2" scale RSJ |
Phil P | 28/04/2020 09:19:32 |
851 forum posts 206 photos | Is the Foliac mentioned above in a paste or flakes form ? I have a few tins of different but fine grades of the flakes type, and I was wondering if that would be suitable for this job. Or is it different stuff altogether. ? It came from my late father's workshop when he died, and would have been used on our full size traction engines. Phil |
Chris Gunn | 28/04/2020 20:01:48 |
459 forum posts 28 photos | Phil, the product I use it is a black sticky paste, the flakes you inherited may well be gland packing. Chris Gunn |
JasonB | 28/04/2020 20:09:12 |
![]() 25215 forum posts 3105 photos 1 articles | Same with mine. |
Phil P | 28/04/2020 20:26:29 |
851 forum posts 206 photos | One thing I have used the Foliac flakes for is to make a spring lubricant. The rear springs on my Morris Traveller were knackered so I treated it to a set of new ones last year, the new ones were not lubricated at all when they arrived and had barely any paint on them either. I made my own concoction using Waxoyl and Foliac flakes mixed 50/50 and after stripping the springs I re-painted between each leaf with this stuff. Then re-assembled them and lathered a bit more on for good luck. I have to say it works wonders, the springs are rust free and working very smoothly still, as it seems to stay put way better than any grease would. Phil |
