OK or myth
Nick_G | 08/06/2014 22:08:24 |
![]() 1808 forum posts 744 photos | . I have read that automatic transmission fluid is a good substitute for headstock oil. Is this true or an internet myth.? (I ask because I have been given a few gallons of it)
Cheers, Nick |
ronan walsh | 08/06/2014 22:40:41 |
546 forum posts 32 photos | Its what i am using in my colchester. I asked about which headstock oil to use on the practical machinist forum, and it seems to be fine, its caused me no problems. Edited By ronan walsh on 08/06/2014 22:41:36 |
stan pearson 1 | 08/06/2014 22:44:20 |
![]() 135 forum posts 2 photos | Hi Nick Myford recommend Nuto H32 which is the same as Hydraulic oil 32, automatic transmission oil is the same but usually red and is also used in power steering. Regards Stan |
John Stevenson | 08/06/2014 23:40:11 |
![]() 5068 forum posts 3 photos | The main difference between ATF and straight hydraulic oil is that ATF has an additive to stop it frothing
Other than that there is no difference |
Muzzer | 09/06/2014 01:37:24 |
![]() 2904 forum posts 448 photos | After much digging about, you will find eventually that the modern equivalent of the factory recommended oil for the Bantam is ISO AW32, which is usually sold as hydraulic oil. Sounds suspiciously like "Nuto H32" and is available for peanuts (by the gallon) at most auto factors. It's also what they recommend for lubricating the slides, BTW. Murray |
Alan Hopwood | 09/06/2014 08:48:54 |
![]() 42 forum posts | Working for a John Deere dealership, I use their Hygard hydraulic and transmission oil in the lathe headstock (Harrison L15) and also in the various gearboxes on the Herbert V47 milling machine. Don't tell anyone, but I use Stihl chainsaw oil on the various slideways Regards, Alan. |
stan pearson 1 | 09/06/2014 11:46:19 |
![]() 135 forum posts 2 photos | ATF and Hydraulic 32 are both none frothing oils, I have now retired but worked for 20yrs on mobile hydraulic cranes most used clear hydraulic oil but Liebherr used red ATF or Dextron R. Stan |
