Neil Wyatt | 01/06/2014 14:30:17 |
![]() 19226 forum posts 749 photos 86 articles | My inverter and motor are both set up for monitoring of motor temperature, but neither manual completely explains it I'd quite like to enable monitoring of the winding temperature. I have a Tec motor and in the control box two wires are brought out to a choc block. The manual hints (but does not confirm) that the motor may have a PT100 sensor. Their website suggests this is actually 3 sensors. It's about 20 degrees in here and the 324 ohm reading is about right for three PT100 sensors in series. All well and good. After running for about 5 minutes, at a couple of hundred rpm, the reading is down to 287 ohms... I've sent a query to TEC, but does anyone have an idea what's going on. Neil |
Thor 🇳🇴 | 01/06/2014 16:38:23 |
![]() 1766 forum posts 46 photos | Hi Neil, looking forward to hear what you find out. I too have e TEC motor with the two temp. sensor wires and an inverter, but don't know how to connect the two. Thor |
John Stevenson | 01/06/2014 16:44:49 |
![]() 5068 forum posts 3 photos | Could find out but our TEC agent has just gone on holiday for two weeks and I'm off to China for 3 weeks so not going to be straight away. |
Neil Wyatt | 01/06/2014 19:33:56 |
![]() 19226 forum posts 749 photos 86 articles | Connecting is 'easy': Thermistor between 11 (0V) and C1 (current input) 1K resistor between C1 and 13 (+10V) There is a diagram on P 2.14 of the Cub manual. C1 is the input to an A2D and uses a 250R resistor to 11 turn the current into a voltage. Wired as shown the 250R is in parallel with the PTC. Activation is not explained well, all the book says (on P.5-9) is program H28 to 1 to activate the PTC, Then you set H27 to a voltage between 0.00 and 5.00, default 1.60. There is no note to explain this in the manual. The two questions for Tec are: 1 The 'ptc' appears to get lower in resistance as it warms up? 2 How do I calculate the voltage as 1by my calculations 1.60 is far too high, but what is 'right'? If Tec don't get back to me I'll be on to you as soon as your feet touch terra firma, John Neil |
Les Jones 1 | 02/06/2014 06:34:48 |
2292 forum posts 159 photos |
Hi Neil, It looks like the motor has an NFC thermistor. I think you will have to transpose the position of the thermistor and resistor so that the voltage to the a2d increases as the temp rises. I am on holiday until June 10th so I do not have access to the manual. I suggest connecting a pot between 0 v and the reference voltage wit the slider to the a2d input. Use this to find out what voltage level trips the inverter off. When you know this you should be able to calculate the resistor value if you can find data on the thermistor that is actually . Les.
Les Jones 1 | 02/06/2014 07:56:37 |
For NFC read NTC. (Noticed error too late to edit post.) Les.
Les Jones 1 | 11/06/2014 10:11:43 |
2292 forum posts 159 photos | Hi Neil, Les. |
Andrew Johnston | 11/06/2014 11:13:46 |
![]() 7061 forum posts 719 photos | A useful rule of thumb is that PTC thermistors are used for heating, in-rush current control and over-temperature protection. A sharp rise in resistance over a relatively narrow temperature is a useful attribute in these applications. For measurement of temperature NTC thermistors are more common, with a non-linear, but well defined curve based on the natural logarithm. Regards, Andrew |
Les Jones 1 | 11/06/2014 12:23:33 |
2292 forum posts 159 photos | Hi Andrew, Les. |
frank brown | 12/06/2014 07:13:19 |
436 forum posts 5 photos | Years ago I was involved with industrial PTC resistors fitted motors on pumps. The "standard" trip resistance then was 600 ohms. The were unreliable, as the PTC resistors were imbedded in the windings before baking and varnishing, they were subject to mechanical strain as the thermal stresses in the winding finally relaxed, so they went open circuit. I believe better motors had the resistors fitted into pockets so they could be replaced. Over the ten years I was involved with the 46 motors, we had about 6 thermistor failures and zero motor failures. If they fail, just fix a contact thermostat to the outside of the motor. Frank |
