Thickness Sander
Stevo25/05/2014 18:19:01
68 forum posts
24 photos
Hi All,
Not sure if this is the right place to post this but I'll give it a go.
I do a lot of work in Balsa, Spruce and Cyparis, occaisionally ash too.
I needed to sand them accurately to a thickness, and later make a jig so I can make taper sections.
So what follows is a collection of 12mm birch ply, 8mm stainless threaded rod, a 1/4HP motor (thanks Maurice!) belts, toothed pullies and so on.
Here goes!
12mm ply discs cut and sanded approximately round:-
Shaft bearings:-
All clamped up!
Main box, lacquered:-
Turning the drum round: -
Machining up some brass bushes: -
Table pivots, fully adjustable:-
This shot is sideways, but shows the main leadscrew of 8mm stainless, tothed pully and brass bush, soldered to a strip of 3mm mild steel. There are locknuts either end, adjustable for backlash, of which there isn't any !
The threaded rod on the right is turns via a handwheel. A toothed belt arrangement turns the rod on the left and the table rises and falls uniformly. All rods are 8mm ball raced:-
Here's the test pass...baby's bum smooth! The top does have a dust extraction point, too.
One thing - I've wound the sanding strip (25mm wide) on and secured it either end via screws - not ideal - anyone have any recommendations?
Thanks wink
Steve
Edited By Stevo on 25/05/2014 18:23:39
Edited By Stevo on 25/05/2014 18:27:01
Bob Brown 125/05/2014 18:40:12
1022 forum posts
127 photos
Steve,
How about using hook and loop sanding rolls? you just need to glue the hook part to the drum.
Bob
Stevo25/05/2014 18:43:02
68 forum posts
24 photos
Thanks, Bob,
I did think of that, but can't think for the life of me why I didn't pursue it...
Neil Wyatt25/05/2014 19:39:20
19226 forum posts
749 photos
86 articles
A surface grinder for balsa wood!
Luvit!
Bob Brown 125/05/2014 20:32:40
1022 forum posts
127 photos
Another option may be to cut a groove, deep enough to recess a strip to clamp the sanding roll.
Stevo25/05/2014 21:39:13
68 forum posts
24 photos
Surface grinder for balsa..
now that did make laugh!!!
Simon Collier25/05/2014 23:37:09
525 forum posts
65 photos
I made a thickness sander in this way some years back for thicknessing guitar backs, tops and sides. The drum is about 2' wide, 6" diameter. I fasten the sanding roll at each end with strapping tape, which was never really satisfactory but I got the jobs done.
Jeff Dayman25/05/2014 23:55:37
2356 forum posts
47 photos
Nice job Stevo, well done. JD
Stevo26/05/2014 10:04:38
68 forum posts
24 photos
Thanks all...
Simon.. did you live somewhere near the south coast?
When I was a luthier I remember visiting someone near Hastings who built thier own drumsander for guitar fronts, backs and sides!!
Simon Collier26/05/2014 10:41:22
525 forum posts
65 photos
Just slightly off target Stevo; I live in Sydney. The plan for the drum sander was on the internet, I seem to remember, so no doubt a few luthiers made them. It is a scary and dangerous thing to operate, pushing the work against the feed of the drum, driven by a 2 h.p. motor, but surprisingly accurate. Any OH&S type who saw it in operation would have a stroke on the spot.
Stevo26/05/2014 11:56:07
68 forum posts
24 photos
Well I wasn't that far out was I? My daughter's backpacking round Australia in October - I'll get her to pop in! laugh
"Any OH&S type who saw it in operation would have a stroke on the spot."
Indeed... Don't invite them to my house...Dust extraction mandatory...
