High Grade Aluminium Supplies
7 series
Involute Curve01/05/2014 12:49:21
337 forum posts
107 photos
Looking for a little help I can get hold of thick plate in 7075 and 7020 in fact I have quite a bit, but I'm trying to source some 7075, 6mm plate and 1/2 in plate, however not large sizes probably buy 1m x 100mm couple of length of each I can get away with smaller lengths they are to machine 50x70 components from, no dims are critical just this sort of thickness's.
any help would be much appreciated
Shaun
Andrew Johnston01/05/2014 12:55:07
7061 forum posts
719 photos
I use Metalfast for aluminium products, they will cut to size if required, or ask about offcuts.
David Senior01/05/2014 20:05:53
30 forum posts
8 photos
I also use Metalfast (or ThyssenKrupp as they are now known) but have recently started using Shropshire Stainless & Aluminium www.ssaltd.net . Not sure whether they will deal without an account, but they are very keenly priced on sawn plate.
Involute Curve02/05/2014 07:55:44
337 forum posts
107 photos
I've used them both in the past and very good the are, but neither do 7075 or 2014 in 6mm or 1/4 plate.
Another good supplier is the Aluminium wharehouse, but again they don't do the above.
Bummer
Speedy Builder502/05/2014 08:25:03
2878 forum posts
248 photos
Have you tried these? I used them in the distant past.
http://www.smithmetal.com/
BobH
Michael Gilligan02/05/2014 08:35:29
23121 forum posts
1360 photos
Shaun,
One more possible source, here
Andrew Johnston02/05/2014 10:25:22
7061 forum posts
719 photos
Posted by Involute Curve on 02/05/2014 07:55:44:
Odd, Metalfast list 2014 in 6mm and 1/4" and 7075 in 6mm in their stocklist. If they hadn't I wouldn't have wasted my time posting. Maybe they're telling porkies?
M0BND02/05/2014 20:00:03
81 forum posts
9 photos
Posted by Involute Curve on 01/05/2014 12:49:21:
Shaun
Does this come under the description of 'shate'? http://www.raaltd.com/alu_plate.htm
Andy.
Edited By M0BND on 02/05/2014 20:05:38
The Merry Miller02/05/2014 20:15:14
484 forum posts
97 photos
As a matter of interest for all concerned:
Up to 6mm (excluding foil or shim) is designated "Sheet"
Above 6mm is designated "Plate"
Len.P
Involute Curve02/05/2014 22:48:07
337 forum posts
107 photos
Posted by Andrew Johnston on 02/05/2014 10:25:22:
Perhaps the web site need updating, when I rang them and Smiths 10mm was the best they could do in the sizes I wanted, anyhow I've sorted it for now, I sliced a couple of bits off a lump of 3" plate I have, it will get me away until I get supply.
