Axle box material
Eric Cox06/04/2014 10:46:55
557 forum posts
38 photos
Making axle boxes for a 3 1/2" gauge loco.
Brass or gun metal
fizzy06/04/2014 12:08:34
1860 forum posts
121 photos
if its an ornimental loco then brass is easy, if you intend running it then cast iron every time. I posted a similar question some time ago.
Aeronut06/04/2014 12:19:23
18 forum posts
39 photos
Hi Fizzy, I'm not wanting to hijack this thread but I have currently got the frames and axle boxes cut for a Martin Evans Buffalo the frames are 3/8" thick and the axle boxes are quoted on the drawings as mild steel with sintered bronze bushes which I already have. Would you recommend me ditching the mild steel axle boxes and use cast iron? There are no horns on this bar frame model the boxes run directly on the frame.
Regards Lee
fizzy06/04/2014 15:41:03
1860 forum posts
121 photos
ive just finished the axleboxes and horns for my invicta, i have used cast for the boxes and steel for the horns, and ensured a 'not tight fit'. Cast should be fine.
Dusty06/04/2014 15:47:54
498 forum posts
9 photos
Eric
Brass is not a good bearing material, if you intend running the loco do not use it, gunmetal is a far better material and as Fizzy points out you can use cast iron.
Aeronut, If you have made the axle boxes stick with the bronze bearings, if not you can have the choice. I would say to both of you make sure you can get adequate lubrication into the axle boxes, over the years i have seen several loco drawings where the provision of oil was poor or even non existant, it is better to have slightly to much than not enough oil.
Aeronut06/04/2014 17:29:35
18 forum posts
39 photos
Fizzy & Dusty thanks for the advice.
Regards Lee
