How to reduce deflection while machining the journals of long slender crankshafts
Bob Rodgerson | 30/03/2014 22:44:55 |
612 forum posts 174 photos | A long time back I machined the crankshaft for a 360 cc flat six. In order to minimise deflection and chatter while machining the various journals I filled the gaps between the webs of previously machined journals with polyester resin by masking off most of the gap and leaving just a small hole through which the resin is poured. When finished drop the crank into a tank of Acetone to dissolve the resin. |
Michael Gilligan | 31/03/2014 08:47:53 |
![]() 23121 forum posts 1360 photos | Neat idea, Bob Thanks MichaelG. |
Steve Withnell | 31/03/2014 18:55:41 |
![]() 858 forum posts 215 photos | For the crank for the Whittle V8, I made some slotted tubes to slip over the crank and used jubilee clips to tighten them up. Like this: Steve |
