Helicoiling before Alocrom finish
James Staniford22/03/2014 11:32:08
9 forum posts
Hi Guys,
Can you insert stainless steel helicoils into aluminium before an alocrom treatment?
Thanks in advance
Ian P22/03/2014 11:35:29
2747 forum posts
123 photos
I suspect not but the people doing the anodising or whatever would know.
Ian P
Bubble22/03/2014 12:38:28
75 forum posts
6 photos
Hi Jqmes
Alocrom is unaffected by steel, brass or copper inserts in the articles being processed
extract from anochrome.com/ alocrom website
Jim
James Staniford22/03/2014 12:44:51
9 forum posts
Thanks Jim, that's great
Clive Hartland22/03/2014 14:11:38
2929 forum posts
41 photos
I suggest you thoroughly flush any threaded or insert holes after Alochrom treatment, I have found that salts do stay in the holes. I find on new parts for the instruments are often not cleansed of residues. Even finding small bits of metal when the holes are blown out. The problem is that these salts can make the fixing screws lock up and snap off on dismantling.
Bill Pudney23/03/2014 03:34:52
622 forum posts
24 photos
When I had to work for a living I vaguely remember putting the following note, or something like it on drawings of aluminium bits.
"Alodine/Alochrom prior to inserting thread inserts".
The reason was that whilst the insert was ok with the treatment, the tiny gaps between insert and parent metal could and would retain small quantities of the stuff. Similar to Clives comment above.
cheers
Bill
