ChrisH | 06/03/2014 18:16:07 |
1023 forum posts 30 photos | I would be pleased if some light could be shed on taper mandrels please. As I understand it, a taper mandrel has a fine taper which holds a small item requiring work to be done to it. What I am unsure about is what is the norm for the included angle of the taper - 1 degree?, more?, less? - and what is the mandrel small end diameter relative to the work being held, that is, is the small end the same diameter as the bore of the work item or slightly smaller, if so, by how much? My thoughts are that the taper must be very fine and the small end diameter a tad smaller than the work bore, but I have no idea how to quantify this. In use, say using MS for the mandrel and something soft like brass or bronze for the work, would one bore the work to exact diameter before mounting on the mandrel, or after, thus allowing any marking or distortion caused by the mandrel to be cleaned up? The latter seems more obvious if the work could be held to final bore it but concentricity might be a problem, but I have never used a mandrel before and thus have no experience with them. Many thanks for any information on using mandrels, Chris |
JasonB | 06/03/2014 18:28:13 |
![]() 25215 forum posts 3105 photos 1 articles | 1deg should be plenty. You want as little play in the parallel part of the mandrel as possible as that is what registers in the bore and the taper is just to hold the item. You generally bore to finished size and then use the mandrel to get at the bits you were holding it by to bore. J |
ChrisH | 06/03/2014 18:58:47 |
1023 forum posts 30 photos | Ah, Jason, are you saying the mandrel has a predominately parallel part and just a wee taper on the end. If so, I didn't know that - but it makes more sense to me. Chris |
JasonB | 06/03/2014 19:07:42 |
![]() 25215 forum posts 3105 photos 1 articles | Yes most is parallel and then it just tapers out at the chuck end. |
ChrisH | 06/03/2014 19:34:05 |
1023 forum posts 30 photos | Thanks Jason, your answers seem to have cleared using taper mandrels up for me, much appreciated, Chris |
Nigel McBurney 1 | 06/03/2014 21:10:43 |
![]() 1101 forum posts 3 photos | Commercially made taper mandrels are tapered for their full length,hardened and ground,the work piece is usually reamed to size then pressed onto the mandrel, the taper is about 1.5 to 2 thou over length,and usually marked plus at the large end,the centres are recessed so that pressing or hitting the end of the mandrel does not damage the centre, they are generally used for between centres turning or used between centres of a dividing head on the mill,for light gear cutting etc , they can produce very accurate work but if buying second hand make sure that they are not bent. The mandrels usually have a machined flat at each end for the clamp screw of a lathe carrier. |
John Stevenson | 06/03/2014 21:45:36 |
![]() 5068 forum posts 3 photos | I agree with Nigel's post, never seen any parallel ones and then a taper unless home made ?
Most of the use I have used them for in the past is on grinding machines. Problem with them is you need hundreds of the damn things to cover only a short scale of sizes. |
JasonB | 06/03/2014 22:21:37 |
![]() 25215 forum posts 3105 photos 1 articles | Yes I. Was talking about home made ones, Harold hall describes the same thing here and I think Sparey and Mason have also
Edited By JasonB on 06/03/2014 22:42:15 |
John Stevenson | 06/03/2014 23:18:16 |
![]() 5068 forum posts 3 photos | OK Jason, we were talking about different animals then. Just threw a handful of rusty pitted ones away a few weeks ago and one orphan the other day, saved them as bar stock but too hard to do anything with. |
Lambton | 07/03/2014 07:38:59 |
![]() 694 forum posts 2 photos | I have a few Jones & Shipman taper mandrels, inherited from my Dad, exactly as described by Nigel. Does anyone know if this type are still made and where can I buy some more ? I know that Arc sell a variety of useful looking expanding mandrels but I find the tapered type very useful for precision work between centres. Eric |
mick | 07/03/2014 08:51:57 |
421 forum posts 49 photos | A taper mandrel has a 0.003'' taper over its entire length. 0.001'' under at one end and 0.001'' over at the other. you probably won't even need to set the compound slide off the zero mark to achieve it. |
JasonB | 07/03/2014 09:16:11 |
![]() 25215 forum posts 3105 photos 1 articles | Mick, -0.001 to + 0.001 is only 2 deg over the length? |
Michael Gilligan | 07/03/2014 09:21:49 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 07/03/2014 09:16:11:
Mick, -0.001 to + 0.001 is only 2 deg over the length? . Jason, Don't you mean thou ? MichaelG. |
ChrisH | 07/03/2014 10:03:24 |
1023 forum posts 30 photos | Jason, thanks for your link to Harold Hall's website explanation, all you ever wanted to know about taper mandrels simply explained! Chris |
JasonB | 07/03/2014 10:13:10 |
![]() 25215 forum posts 3105 photos 1 articles | Yes Michael I meant thou but its still two and not three |
John McNamara | 07/03/2014 11:14:18 |
![]() 1377 forum posts 133 photos | I have a set that in some ways work like ER collets in reverse, The taper is the bore the outside is parallel. There is also a set of centred and ground tapered mandrels that fit inside the Taper bored collets. The set covers from about 12mm to 40mm. This set is similar: **LINK** Regards
jonathan heppel | 07/03/2014 14:24:55 |
99 forum posts | Why are taper mandrels used with an arbor press? English as she is spoke I guess. |
mick | 07/03/2014 17:09:57 |
421 forum posts 49 photos | Hi Jason. How can you work out the angle without knowing the length? |
ChrisH | 07/03/2014 19:04:30 |
1023 forum posts 30 photos | Hi Michael, many thanks for your explanations, much appreciated, Chris |
Nigel McBurney 1 | 07/03/2014 19:42:04 |
![]() 1101 forum posts 3 photos | The mandrel that gets the most use is a one inch dia on which I mount various milling cutters for cutter grinding, I bought this second hand,my smaller ones I bought new forty odd years ago I think they were Jones and Shipman another fine company gone for good when governments let our engineering industry go to the wall, I have not seen any new ones for sale,probably no use in modern production engineering now that wonderful things can be cnc machined with little second op work. |
