Internal keyway on a lathe
John Hewes04/02/2014 18:34:20
22 forum posts
Hi, I need to cut a keyway in the bore of an aluminium alloy pulley for a wood turning bowl lathe drive.
I am planning to do this on my Boxford lathe by making up a boring bar to almost the bore size and fitting an adjustable cutter near to the end so that I can use it as a broach, a little at a time.
Any advice, please as I haven't done this before.
Two specific questions:-
Is it sufficient to lock the faceplate by engaging the back drive as well as the mandrel drive pin?
Do I need a leadscrew handle, or should I just use the saddle handwheel?
Thanks in advance
JasonB04/02/2014 18:41:00
I've done it several times and just used the saddle handwheel and the lowest gear to hold the chuck. Just take a couple of though at a time and let the spring work out of the tool once you get to depth.
You should not need to move the cutter in the tool once its set just wind the cross slide back towards you.
In alloy the tool should not bee dto be massively thick, I have used a 1/2" boring bar with a 5/32" HSS square tool bit in steel without problems.
Stub Mandrel04/02/2014 19:07:05
4318 forum posts
291 photos
Unless your tool shape is very poor, there will be no forces trying to rotate the work, so you don't need heavy duty clamping. Also, once you have started the groove it will tend to guide the toolbit.
A sharp tool is essential as the force to take cuts may be more than you might expect. As Jason says, expect to work the spring out of the cutter.
Also make sure there is plenty of relief on the front of the cutter (the side facing you).
Clive Foster04/02/2014 19:26:32
3630 forum posts
128 photos
Job goes a lot faster if you drill a hole to remove most of the material first so your tool merely has to bring the hole to shape rather than cut it from scratch. Plug the bore with a spigot of the same material and set the drill centre just inside the junction between bore and plug so the part circle hole is a little shallower than the keyway depth.
How close to the keyway width you choose to drill is down to your nerve and equipment capabilities. I find something around the 0.5 mm - 1/32" undersize works fine.
First time though its probably best to draw things out so as to get a feel for relative positions of hole and final keyway. Easy with CAD. Especially if the keyway is shallow th eprocess is not quite as obvious as it appears.
John Hewes04/02/2014 22:20:27
22 forum posts
Thanks all for your advice.
I'm not sure Clive that I can drill such a small hole accurately enough though. I suppose I have several tries around the hole if I mess it up!
Les Jones 104/02/2014 22:56:51
2292 forum posts
159 photos
Hi John,
I find it better to have the tool cutting when pulling it towards the tailstock. It is less inclined to dig in.
Les.
Thor 🇳🇴05/02/2014 05:24:05
1766 forum posts
46 photos
Hi John,
if you have access to a milling machine and the pulley isn't to large for the milling table you could first mill the keyway before broaching.
Thor
IanT05/02/2014 09:24:17
2147 forum posts
222 photos
Or find someone (Club/Friend?) with a Shaper of course!
IanT
Brian Wood05/02/2014 11:09:03
2742 forum posts
39 photos
Hello John,
I have in the past made a bush with a sawn out and carefully filed key slot on one side and fitted that to the bore of a pulley for a similar fix. Once the Loctite had set I drilled a small hole on the joint face to contain a locking pin and then turned the bore of the bush to finished size with light cuts.
It saved me hours of planing away using the broaching method and worked just fine
Brian.
Nigel Bennett05/02/2014 12:42:54
500 forum posts
31 photos
When doing this, I always secure the lathe spindle. Ensure the lathe power is switched off. Stick a chuck key in the chuck and tie a weight to it to take out any movement in the lathe spindle.
John Hewes09/02/2014 10:31:42
22 forum posts
Hello again.
Just to let you know that I managed this fine with all your help, Gents, thank you.
Nigel, I took your advice, but used a bungy rubber to hold the faceplate in place.
I now have another question but will start a thread under "beginners".
