Does anyone know of one?
richardandtracy | 25/11/2013 10:21:13 |
![]() 943 forum posts 10 photos | I have a question: Does anyone know of a variable radius toolpath wrapper program? I want to engrave the surface of some pens and have realised that the standard wrapper type program that assumes a fixed work radius is quite a serious limitation the decoration that can be applied to the pens. Does anyone know of a program where a profile can be entered and also the un-wrapped toolpath so the two can be combined to make a generalised wrapper for parts with both cylindrical and non-cylindrical sections? I have been thinking about how I would do it myself, and the programming would be far from easy - making a cylindrical wrapper seem quite simple in comparison. Regards, Richard Edited By richardandtracy on 25/11/2013 10:25:59 |
jason udall | 25/11/2013 11:05:35 |
2032 forum posts 41 photos | I was about to refeer you to a thread here but since you started that one..![]() |
richardandtracy | 25/11/2013 11:55:02 |
![]() 943 forum posts 10 photos | Jason, The wrapper program I wrote does cope with compound curves provided it is a Z component to an XY plane arc, I have a feeling it wouldn't be too difficult to make it work with XZ and YZ plane arcs. In fact, I'm not entirely sure why I didn't incorporate XZ & YZ plane arcs - possibly because CNCWrapper only works in the XY plane and I wasn't thinking things through, probably was as simple as that. It doesn't, though, make it easy to have a variable radius work. Imagine something like a sphere, and you wish to machine angled slots to a constant depth on the surface of that sphere. With the current wrapper idea you'd need to incorporate the changing radius of the sphere in the input file Z axis. It would be nicer to have a reference profile and the input file to be on the flat, where it is much easier to think about, draw and create the toolpath code. Then the variable radius wrapper puts in all the A axis stuff as well as all the Z components necessary to cope with the varying work diameter. Regards, Richard
Edited By richardandtracy on 25/11/2013 11:58:34 |
David Jupp | 25/11/2013 13:04:40 |
978 forum posts 26 photos | Some CAM programs allow you to project text onto the (non-flat / non-uniform) surface of an object, and they will then work out tool-paths. Wrapping and projecting are different, so this may not be what you want - or it may be close enough... |
richardandtracy | 25/11/2013 13:26:17 |
![]() 943 forum posts 10 photos | Projecting would be close enough. The projected path could then be wrapped. Can I ask, what packages (preferably free!) can do this? Regards, Richard |
blowlamp | 25/11/2013 15:25:57 |
![]() 1885 forum posts 111 photos | CamBam will do that. Just import an STL surface and you can project text and curves onto it. Then use an Engrave operation to generate the toolpaths.
Martin. |
richardandtracy | 25/11/2013 15:44:50 |
![]() 943 forum posts 10 photos | Thanks Martin. I shall investigate that - it sounds like a good option. Regards, Richard. |
richardandtracy | 26/11/2013 08:15:09 |
![]() 943 forum posts 10 photos | Michael, I am trying to make life easy for myself, not make a lifetime's work in getting to the point where I can start machining... When pen making, which is what I want to do, the deviation from a constant radius cylinder is not usually huge, so shrinking the engraving to fit a taper won't have a serious effect on the design and won't look too bad. It will, however. look very unusual. Regards, Richard
jason udall | 26/11/2013 09:16:12 |
2032 forum posts 41 photos | Mm don't people do something like that on wine glasses ?...may be take a google of "eggbot".. |
blowlamp | 26/11/2013 09:58:17 |
![]() 1885 forum posts 111 photos | A way to project the text onto a surface in CAD and transfer it to CAM. **LINK**
Martin. |
richardandtracy | 26/11/2013 12:06:34 |
![]() 943 forum posts 10 photos | Interesting CAD package, Martin. Which one was it? I don't recognise it. Have played with AutoCAD/DraftSight & SolidWorks, but no others. Regards, Richard
blowlamp | 26/11/2013 12:18:34 |
![]() 1885 forum posts 111 photos | It's MoI. See here
Martin. |
richardandtracy | 26/11/2013 13:24:01 |
![]() 943 forum posts 10 photos | Thanks Martin, you've given me 2 avenues to explore now, much appreciated. Regards, Richard |
