Dore Westbury Milling Machine
Drive Belt
Smudge13/09/2013 20:49:37
18 forum posts
Hi
Can anyone help, i need to buy some replacement drive belts.
It is an "O" drive belt.
Thanks for your help
Smudge
NJH13/09/2013 22:16:48
2314 forum posts
139 photos
Hi Smudge
I don't know that you will get them but Tony, at Lathes.co.uk, does supply various belts and belting. See HERE
A 'phone call to him would find out and, even if he doesn't have one suitable, he may well be able to point you in the right direction.
Good Luck!
Norman
Edited By NJH on 13/09/2013 22:17:41
Smudge13/09/2013 22:42:59
18 forum posts
Thanks Norman
Brian Wood14/09/2013 08:27:10
2742 forum posts
39 photos
Hello Smudge,
I bought two recently froim www.motionco.co.uk
They do mail order, in the diameter you need and I would recommend you order a size [which you specify] that is tight rather than "easy", they stretch quite a lot from new.
Nest wishes Brian
Ian S C14/09/2013 12:12:28
7468 forum posts
230 photos
You could use heat fusable round plastic belting, its good, although the only machine I run with it is my Super Adept, it has two bits of 5 mm belt, one from motor to jack shaft, the other from jack shaft to the lathe.
I do use 3 mm dia as drive belts on my Stirling Engines. Ian S C
Smudge14/09/2013 21:27:58
18 forum posts
Hi Guys
Thanks Brian & Ian
I should get sortted now
