BOXFORD SCREWCUTTING GEARBOX
RICHARD GREEN 216/08/2013 13:06:13
329 forum posts
193 photos
Has anyone ever fitted a screw cutting gearbox to a Boxford BUD or CUD lathe ?
Are there any castings or drawings to make one ?
Richard,
John Stevenson16/08/2013 13:14:01
5068 forum posts
Never seen one, only the Machin and earlier version for the Myford.
One point is that if you need to change ratios a lot between special and metric etc that can be more hindrance than help. I fitted a genuine Myford box to my ML7 and regretted it from day 1.
Having said this if you predominantly work only in imperial I can see where they will save time.
Speedy Builder516/08/2013 16:06:55
2878 forum posts
248 photos
Could try this
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.Xboxford+gearbox&_nkw=boxford+gearbox&_sacat=0&_from=R40
Gear wheels are £15 a piece and there are 13 or more in the box !! Plus you will need most of your standard gears plus the 100/127 metric convertor plus a few other gears to cut a good range of metric threads. It could work out a bit expensive. May be time to replace the lathe and sell yours ? Having said that, I love my Boxford and there would have to be a very good reason for me to get rid of it.
Anyway, good luck with your project - an article in MEW ??
Bob
Edited By Speedy Builder5 on 16/08/2013 16:07:52
Edited By Speedy Builder5 on 16/08/2013 16:09:40
_Paul_16/08/2013 21:21:07
543 forum posts
31 photos
All the Boxford A,B,C, AUD,BUD,CUD & TUD beds I have seen have the three pre drilled holes for the Boxford gearbox either Imperial or Metric.
Never seen one fitted with an "aftermarket" box.
You occasionally see genuine gearboxes on Fleabay for around £250 which is around what building a Myford compatible Machin/Hemingway gearbox may cost to construct let alone something bespoke.
A South Bend gearbox may also fit best place to ask that question though is the South Bend Yahoo group.
The old Boxford I have is imperial I dont cut many Metric threads on it but when needed it's not that much of a job to slip on the 100/127 compuond gear and whatever stud gear for the needed thread.
Paul
