john kennedy 1 | 26/07/2013 16:21:21 |
![]() 214 forum posts 24 photos | Hello,hopefully someone can advise me. I have one of these machines **LINK**. The standard horizontal version,the previous owner aquired a vertical head for it which works well enough. There was a lot of slack in the X and Y directions so I've fitted new leadscrews and nuts. The problem is I've lost the X power feed and need to make one. I suppose a windscreen wiper motor conversion will be too weak for this machine ? Would it be possible to use a stepper motor and presumably a driver with a directional switch and speed cotroller or will I have to set up a 1 axis cnc machine ?? I have a spare laptop so could do that. Any idea how big a motor I might need ? I wouldn't know a Ncm if I fell over one. Hope someone can help. Thanks John. |
dcosta | 26/07/2013 17:25:00 |
496 forum posts 207 photos |
Hello John, good after noon. |
john kennedy 1 | 26/07/2013 17:39:30 |
![]() 214 forum posts 24 photos | Dias, thats great just what I want. How do you control it ? How do you power it? How do I calculate the size? Do I need to gear it down as you have? I know nothing about it and have loads of questions. Thanks for putting the pictures up. Perhaps you can point me to a forum where I can learn a bit more.John |
dcosta | 26/07/2013 18:51:04 |
Hello John, |
john kennedy 1 | 26/07/2013 21:38:08 |
![]() 214 forum posts 24 photos | Thanks for that Dias,very helpfull. Read the driver details and I see the speed pot and direction are all with it.Will see about getting the bits together ...John |
Douglas Johnston | 27/07/2013 08:49:32 |
![]() 814 forum posts 36 photos | I am in the process of building an X axis driver and found that the latest 400Ncm stepper motors give a decent torque without being too large and heavy. I got mine from CNC4YOU along with a driver which uses an ac power supply (up to 60V) which makes the power supply simpler to construct as all you need is a transformer. You can do clever things with multi stepping, rapid traversing and using the enable control on the driver to remove power from the motor when it is not driving the table, which prevents the motor from overheating. Some form of variable pulse generator is also required to operate the motor driver. Doug |
john kennedy 1 | 27/07/2013 10:15:00 |
![]() 214 forum posts 24 photos | Doug, Looks interesting although the price rises a bit. Any photos ? John |
Douglas Johnston | 27/07/2013 17:52:14 |
![]() 814 forum posts 36 photos | Very true John, not cheap but very nice! I've reached an age where saving money is less of a priority, no point in dying rich, although I intend living for quite some time yet. The drive is not complete yet but I will dust off the camera and see what I can show so far. Doug |
john kennedy 1 | 27/07/2013 18:47:26 |
![]() 214 forum posts 24 photos | Doug,that made me laugh. I'm at the ripe old age of 62 and can't say I've had those feelings yet. One thing for sure though is that whatever I do I won't die rich . Look forwar to the photos..John |
Douglas Johnston | 27/07/2013 20:58:59 |
![]() 814 forum posts 36 photos | Well John I will be 65 in September so still very much a youngster. I have added some pictures to my album and as you can see there is still quite a bit to do. The trouble is I keep needing to use the milling machine for other things so progress is delayed.Any questions, just ask. Doug |
mark mc | 28/07/2013 08:12:13 |
92 forum posts 16 photos | I've been thinking about trying this out too for awhile, thanks dcosta. Time to order some bits. |
