Testing And Wear On Cross Slide
woody1 | 12/05/2013 14:50:22 |
![]() 91 forum posts 21 photos | Afternoon Fellas its been a while. I would like to check my cross slide's alignment to the head stock. I'm quite un-sure how to test though? I have a pretty good idea my cross slide moves at an angle away from the work guys. Thought I would ask before fidiling (did do a search before posting). I realise an idicator is needed but where to mount with out getting a false reading? I have an indicator which I can hold in the 4 jaw. I was thinking of offsetting the indicator low enough so it is able to touch the face of the cross slide. Cheers fellas. David. Edited By woody1 on 12/05/2013 14:56:32 |
Les Jones 1 | 12/05/2013 15:30:38 |
2292 forum posts 159 photos |
Hi David, Les
Andyf | 12/05/2013 15:52:21 |
392 forum posts | David, Not sure if "my cross slide moves at an angle away from the work" means that facing cuts tend to leave the surface concave or convex (the terms are used loosely, because the shapes involved are really conical) but I had a similar problem and measured the amount of dishing as shown here . After making the test facing cut, a dial indicator mounted in the toolpost should show no deflection as it is run from the near side of the work to the centre, because it is following the same path as the tool took. But (assuming the facing cut has a bit of concavity/convexity) when the DI is run from the centre to the far side, its reading over that radius of the workpiece will represent double the amount by which its centre is up or down in relation to its circumference. Dead flat would be perfect, but it is better to be cautious and aim for a bit of concavity rather than convexity. The latter would mean that a faced item would rock when placed on a flat surface, whereas a slighlty concave item wouldn't. I didn't find this an easy fix.... Andy
Nobby | 12/05/2013 18:35:55 |
![]() 587 forum posts 113 photos |
Hi |
Andyf | 12/05/2013 20:43:52 |
392 forum posts | Nobby, if the out of perpendicular cross-slide is a manufacturing fault, David can't true up a faceplate. Sort of chicken and egg situation. Gray, if the owner of the mini-lathe you mention is who I think it is, he emailed me about it before saying that he was lucky enough to have put it in your capable hands. It would be good to see details of how you sorted it out. Andy Edited By Andyf on 12/05/2013 20:50:00 |
Nobby | 13/05/2013 09:59:15 |
HI Nobby |
Andyf | 13/05/2013 10:35:01 |
392 forum posts | "Perpendicular" usually means the same as vertical, Nobby. But in geometry it means, to quote from my big (20+ volumes) OED, "Of a line or plane: having a direction at right angles to a given line, plane or surface." In my schooldays, when dinosaurs roamed the earth, we were taught how to use compasses to construct one line "perpendicular" to another. Verticality didn't come into it; the paper was flat on the desk. Thus, I was meaning that the motion of David's cross slide was not perpendicular to his spindle axis, resulting in concave or convex facing cuts. Andy |
Martin Kyte | 13/05/2013 13:54:13 |
![]() 3445 forum posts 62 photos | How about fitting a piece of square bar in the chuck accross the jaws. Put a plunger type indicator in the tool holder and bring up to touch the bar at a point a couple of inches off axis. Tighten down the saddle slide and mark the point on the bar. Rotate the chuck 180 degrees advance the cross slide to the same point and recheck. The difference between the indicator readings will give you the error over the advance of the cross slide and thus the angle. Sould be slightly closer to the chuck at the back point. If it's further away, worry. You may have to jiggle things so you have enough cross slide travel for both points. Hope that makes sense regards Martin |
John McNamara | 13/05/2013 16:35:18 |
![]() 1377 forum posts 133 photos | Hi Woody It will help if you put a (tested straight) bar in the four jaw chuck, then firmly but no more tighten the bar in the chuck. It is very important not to over tighten and distort the bar. Then rotate the chuck and bar testing against an indicator mounted on the cross slide or the lathe bed touching near the end of the bar, If the indicator measurement is not the same when the bar is rotated end for end lightly tap the bar until both ends have the same indication. Once this is done you know that the face of the bar is at 90 degrees to the axis of the machine, and you have eliminated any error that may have been introduced by the chuck or face plate. Then once set rotate the bar until it is horizontal, and move the cross slide with an indicator fitted touching the bar it in and out You be able to see any errors at any point along the bar. It is accepted (By some) that if there is an error it should make the lathe face slightly concave. maybe .0002" over a foot but never convex.
Cheers
Nobby | 13/05/2013 16:58:46 |
Hi Edited By Nobby on 13/05/2013 17:09:37 Edited By Nobby on 13/05/2013 17:13:24 |
Stub Mandrel | 13/05/2013 21:43:36 |
![]() 4318 forum posts 291 photos 1 articles | Hi Gray, I can't understand what you are measuring in that picture? Surely the saddle can't move across the bed... so what am I missing? Neil |
Les Jones 1 | 13/05/2013 22:51:34 |
Hi Gray, Les. |
John McNamara | 14/05/2013 12:53:28 |
![]() 1377 forum posts 133 photos | Hi All The method using a ground rod above does not take into account the cross slide itself and its relationship with the saddle. Maybe on brand new fresh ground dovetails it will give a fair result. However after use the wear is uneven. If there is any concavity on one or both of the faces of the single dovetail slide measured on the saddle it will be bridged by the bar and wear will be be difficult to detect. Actually there are two dovetails with eight mating surfaces and they work together, half are ignored. I think the results will be more accurate if the assembly is tested in its entirety as detailed above in previous posting. On an older lathe if you tighten the gib's carefully in one position, and you should start in the typical working position normally towards the middle, and then move the cross slide through its range of travel you are almost certainly going to feel resistance at some point in the cross slide travel,often with the cross slide moved out towards the operator because most work done on a typical lathe is smaller diameter and the wear happens over the area where it is most used with the cross slide moved forward. if resistance is found there is clear evidence there is an error in the geometry, most likely wear. This wear can be easily be confirmed by the use of two short say 20mm long (Matched diameter) cylinders that bear roughly in the centre of the dovetail flats by measuring over them while lightly pressed into the V on the saddle dovetails at various points along the length of the dovetails with a micrometer, Or between them If you have taper gib's on the cross slide itself. With screw type gib's only the saddle can be measured, In this case the fixed edge of the cross slide can be measured with a wedge straightedge and marking blue for straightness and flatness. And the gibb itself can be inspected for wear separately. If wear is found it can be corrected by scraping or grinding. but don't do it if you have not done it before until you have researched how, have the necessary tools and are confident, a toolmaker friend will be a great help. The above test does not establish that the saddle travel is at 90 degrees to the spindle axis, that can be done by the test bar at 90 degrees to the spindle axis rotated in the chuck proposed in the previous post.
The spindle axis should also coincide with the axis of the bed ways, That is another separate test requiring a test bar normally about 300mm exposed mounted on the spindle and collinear to its axis. it must be tested vertically and horizontally. Inevitably there will be many small errors in any mechanical system but with simple tools we can reduce each of them to an acceptable level.
Cheers Edited By John McNamara on 14/05/2013 12:56:02 |
Chris Heapy | 14/05/2013 13:26:08 |
209 forum posts 144 photos | I'm with John on that, and I would add it is better to disengage the leadscrew and push the slide by hand to feel the resistance. Hopefully the steel gib strip will wear faster than the cast iron slide so replacing the strips with new ones may offer some improvement, otherwise it will be necessary to get the parts re-ground. If you're in the habit of using a slide locking screw (which presses against the gib strip) then this is often a source of localised and uneven wear. |
Stub Mandrel | 14/05/2013 21:05:23 |
![]() 4318 forum posts 291 photos 1 articles | Understood Gray, you are taking two measurements and it is the probe that moves. I would do the test on my lathe, but after several tries I can't find a way of mounting either my DTI or my dial gauge in a way that allows me to do that without making a new mount! Neil |
Andyf | 14/05/2013 21:11:23 |
392 forum posts | Thanks for showing, Gray. I bet the owner will be as pleased as punch. Andy |
Andyf | 14/05/2013 23:57:55 |
392 forum posts | Gray, you said: "This is just a thought, both the lathes I have recently attended to had their headstock bearing adjustment loose, I mean physically loose, (undone), before you go too far have you checked yours recently, or have you done the taper bearing conversion?" If you mean end float on the spindle, perhaps this happens on mini-lathes because the spacer tube between the "end float nuts" on the outboard end of the spindle and the bearing in that end of the headstock is often made of plastic. Might it slowly deform, allowing a bit of end float to creep in? Or perhaps you meant that the locknuts were simply loose on the spindle, and not locked together. Andy
Andyf | 15/05/2013 10:00:31 |
392 forum posts | Hi Gray, As you probably know, these minilathes are made by one or other of the Chinese firms Sieg and Real Bull (!). There are detail differences between the two versions, but most parts are interchangeable. I believe the current Sieg machine comes with a plastic spacer but your photos show that you are dealing with a Real Bull, so it may have a metal one. Andy PS I have never owned either machine. My knowledge of them stems from my being (for reasons which have always eluded me) a moderator of the Yahoo 7x12 minilathe group, so I see a lot of comments about their idiosyncracies (to put it politely). I agree with your earlier comment that basically they are soundly designed little machines. But, being at the budget end of the market, many examples are let down by poor standards of fit and finish, and things like plastic spacers. |
Stub Mandrel | 15/05/2013 13:14:45 |
![]() 4318 forum posts 291 photos 1 articles | I have indeed made the taper bearing conversion. I periodically attempt to rock the spindle in its bearings, but the only time it was loose was soon after fitting the bearings - I probably hadn't fully bedded one of the races. In the future I hope to get a VFD for the mini-lathe. If this happens I will build the motor into the lathe stand and completely strip down and re-assemble and set up the lathe as best I can. Neil |
Nobby | 15/05/2013 15:06:25 |
Hi Guys |
