john fletcher 1 | 04/05/2013 14:36:53 |
893 forum posts | My friend has a Chester milling machine fitted with power cross feed which has a fault.Over the phone he says it blows the fuse,he says the transformer is OK 240 in 110 out, he also says the motor runs.I got the pcb and checked out the thyristor (its not easy to get access to unsolder it and test it) its OK.Any ideas or help would be appreciated before visiting.Ted Contact me:
John Rudd | 04/05/2013 17:03:40 |
1479 forum posts 1 photos | John,
What test equipment do you have? A multimeter is essential for fault finding. You say it blows fuses...So is the transformer and motor and scr....So the fault must be on the pcb? When the fuse blows is it blackened? Assuming its a clear glass fuse. If so then there's a dead short somewhere.. What about an on-off switch..Does it have one? does it check out ok? I've had switches go short across the mains before so wouldnt rule it out.. |
Les Jones 1 | 04/05/2013 19:03:59 |
2292 forum posts 159 photos |
Hi John (f), |
John Stevenson | 05/05/2013 22:43:03 |
![]() 5068 forum posts 3 photos | John, Here is the manual on the 300, 400 and 500 series units.
john fletcher 1 | 06/05/2013 08:08:18 |
893 forum posts | Many thanks to all who have replied to my request for help,good to know that folk like you are still around. I have copied the circuit diagrams,so will be studying them. Well regarding the transformer I was told that it tested out OK and that the motor had been loosely connected ( direct to the transformer) and that tested OK. So it leave only the pcb which I recieved and it tested OK, could be a duff micro switch. I will get over and see my friend next week very busy this week, Harrogate show amonst otherthings. I have a couple of multimeters, I am quite well equipt with test gear. Many thank once again I will let you know the outcome.Ted |
DavoJ | 07/05/2013 01:40:36 |
9 forum posts | A lot of people with these power feeds have found the pot goes on them. I have one that has the jitters, it stutters as it moves, but I changed it with the knee one and it seems fine there as I only rapid the knee.
Dave |
