Soft Solder
Hand rails Gauge 1 loco
Alan Church19/03/2013 20:33:21
8 forum posts
Whats the best way to attache the very small hand rail stanctions as used on Gauge 1 Lococ's? The ones I have are not threaded and I have been told to soft solder them in. As you known various solders have a wide range of melting points. So what's the best solder, or should I arladite them in.
Any advice greatly recieved
CuP Alloys19/03/2013 20:56:32
45 forum posts
Hi Alan,
The easiest soft solder to use is 60/40 tin lead.
Melting point 187deg C. Free flowing producing small neat fillets.
For small joints as described use paint.
It is 60/40 tin lead powder mixed with a flux and binder. Paint it on the components, assemble and heat gently. Wash with water.
Product is readily available.
regards
keith
mick H20/03/2013 07:53:39
795 forum posts
34 photos
Alan.....a short while ago on the Gauge 1 forum someone gave this advice. If the stancions have have a small spur on the underside, then a 10 or 12 BA thread can be formed and the stancion can then be nutted on. I think the correspondent on the G1 forum backed this up with a touch of solder to hold the nut in place although if you manage to get a good thread I am sure Loctite or similar would do the job. I obtained my stancions from Walsall Models and they have a spur.
Mick
Russell Eberhardt20/03/2013 17:10:52
2785 forum posts
87 photos
Posted by CuP Alloys on 19/03/2013 20:56:32:
Also available as solder paste in syringes. It is easy to deposit small quantities without waste or mess.
Russell.
