Kevin Norman | 30/01/2013 12:00:35 |
34 forum posts 1 photos | Does anyone know where I can obtain castings for the Grasshopper Engine by Sydney Owen, I know that Brunell do a similar engine but I do not really want to go down that path. Kevin |
David Clark 1 | 30/01/2013 12:09:38 |
![]() 3357 forum posts 112 photos 10 articles | Hi Kevin Why don't you talk to Grahame? He may have it in stock. Give him a chance, see if you can do a deal. regards David |
JasonB | 30/01/2013 12:40:50 |
![]() 25215 forum posts 3105 photos 1 articles | How similar do you want it to be? Bruce engineering do the Easton & Anderson that Anthony Mound described Stuart Models also do a grasshopper Or you could just make it from scratch possibly substituting a cylinder and flywheel casting from one of the other beam engines that Reeves do. I'm well on my way to completing a scratch built E&A at double the size of teh bruce offering with a lot more detail added, see here J Edited By JasonB on 30/01/2013 13:01:47 |
Kevin Norman | 30/01/2013 13:08:40 |
34 forum posts 1 photos | Thanks for your answers, I already have the drawings for the Syd Owen Grasshopper Engine and the two that have been mentioned from Bruce eng & Brunell do not fit the bill. My question was does anyone know of suppliers of castings for this particular engine , if not I have found a suitable flywheel and would machine the rest of the components from solid. Kevin |
JasonB | 30/01/2013 13:22:17 |
![]() 25215 forum posts 3105 photos 1 articles | I've never seen castings available but they may have been in the sixtys when the article was writen
J |
Ian P | 30/01/2013 13:48:23 |
![]() 2747 forum posts 123 photos | Kevin Sorry I cannot help you find an answer but I think David C has already mentioned the name of a potential supplier, he replied just few minutes after you first posed the question I must admit that its not a supplier I know of, so you will have to Google it (or as DC again)
Ian |
Kevin Norman | 30/01/2013 13:54:15 |
34 forum posts 1 photos | Thanks for your answer Ian , the supplier that David mentioned was Brunell and the Grasshopper Engine they do is not what I require. Kevin |
Ian P | 30/01/2013 14:14:55 |
![]() 2747 forum posts 123 photos | My reply was meant as a dig at DC! I was not sure whether he was being ultra neutral as a moderator (in that he did not show any bias to any one supplier), but also, his reply meant absolutely nothing to anybody that did not know anybody called Grahame. I know two people called Grahame but niether of them knows anything about casting, on the other hand one of them does go fishing, Ian |
David Clark 1 | 30/01/2013 14:26:23 |
![]() 3357 forum posts 112 photos 10 articles | Hi Ian I misunderstood. I thought you did not want to use Brunel for reasons posted on another thread. I did not realise the engine was not what you want. One of the Model Engineer contributors made it from the solid + a flywheel casting I think. I think he wrote it up in ME but not dead sure. That engine was an update of one published in ME back in the late40s, early 50s I believe. It was also originally metric. regards David |
JasonB | 30/01/2013 15:11:52 |
![]() 25215 forum posts 3105 photos 1 articles | Would that be the one by A. Ebeltoft from March 1949? I have the drawings for that which are indeed in metric. Kevin, PM me if you want a copy. Looks to be quite doable from solid and possibly a 5" Stuart Flywheel, bit on the small side for me but doubled up with a 10" wheel would be nice. J |
David Clark 1 | 30/01/2013 15:20:04 |
![]() 3357 forum posts 112 photos 10 articles | Hi Jason I think that is the one. regards david |
Kevin Norman | 30/01/2013 16:25:11 |
34 forum posts 1 photos | The original design was by Ebeltoft but the drawings that I have are for the one serialised in ME Nov -Dec 1965 , I have the extracts from these issues. The size of the engine is 13" long x 13" high x 61/2" wide and has 8 1/4" diam flywheel.
Kevin |
JasonB | 31/01/2013 16:39:34 |
![]() 25215 forum posts 3105 photos 1 articles | Happened to be looking at Hit & miss engines and remembered that Canadian Model Engineering do a Grasshopper that is a dead ringer for the Owen one but looks to have been scaled up 50%. from the earlyer design, I had assumed they were the same size
Edited By JasonB on 31/01/2013 16:42:42 |
Jo | 31/01/2013 18:01:06 |
198 forum posts | All the dimensions of that Canadian Grasshopper match the 1965 Sydney Owen design. Jo |
JasonB | 31/01/2013 18:25:26 |
![]() 25215 forum posts 3105 photos 1 articles | Thanks Jo, another one to add to the collection? J |
Kevin Norman | 31/01/2013 18:44:19 |
34 forum posts 1 photos | Thanks Jason, It matches the Syd Owen one to a tee , I will e-mail Canadian for more details. By the way what size of boiler would I need to power this size of engine?
Kevin |
JasonB | 31/01/2013 18:50:37 |
![]() 25215 forum posts 3105 photos 1 articles | Probably 4-5" dia the capacity is largish but hopefully it won't want too much steam as it should be quite slow running. I have heard that their Hit & miss castings are good quality so the same should apply to the steam engines. Make sure you post some pictures of progress. |
Jo | 31/01/2013 18:51:37 |
198 forum posts | Jason,
I am still trying to be good and not buy any more castings. I already have my eye on something very sexy to add to my collection, something that I have no doubt will be both challenging and I anticipate will find very rewarding Jo
Edited By Jo on 31/01/2013 18:53:50 |
Kevin Norman | 31/01/2013 19:03:53 |
34 forum posts 1 photos | Thanks Jason, my GLR 4" vertical should be OK then. Kevin |
