What lathe tools
chris j13/01/2013 19:45:13
338 forum posts
17 photos
Hi guys
I am off to the show at Ali Pally at the end of the week and one of the things I'm looking for is a set of lathe tools.
My tool post will take 16mm square tools but do I need to go that large ?
Any recommendations for general workshop use.
Chris
JasonB13/01/2013 19:57:58
Watch some of the sets of indexable tools as they have some very obscure tips. Try to keep to one or two tip shapes
I would go for 12mm unless you intend doing a lot of heavy work and buy individual tools rather than sets which tend to have ones you will seldom use.
Assuming you are looking at indexable tools then I would go in order of most used:
R/H turning, this will turn along the work & face CCMT type tip
Parting
6mm &10mm boring bars CCMT, 16mm is nice for deeper holes
Through turning to use the other two sides of an 80deg tip
L/H turning handy for facing larger items and working away from the chuck
Most of mine are Glanze but also have a look at Greenwood who are usually there
Edited By JasonB on 13/01/2013 19:59:30
chris j13/01/2013 20:19:51
338 forum posts
17 photos
CCMT ??
Any parting tool prefence please
Thanks
JasonB13/01/2013 20:33:35
CCMT, it describes the general shape of the tip and is what most of my tooling takes, readily available in a range of sizes and material specific versions.
I use three types of parting tool, A narrow 0.050thou HSS one (chronos ref PTO000) good for small work below 1/2dia, 3/32 HSS in the holder for my Dickson QCTP and a 2mm Glanze jobbie
Andrew Johnston13/01/2013 20:48:57
7061 forum posts
719 photos
Nothing to add to Jason's advice. The designation CCMT is the first part of the ISO description of tool inserts:
C - Rhombic shape, 80º nose angle
C - Relief angle 7º
M - Tolerances ±0.013mm
T - Single sided, partly cylindrical hole, with a 60º countersink, ie, held by a central screw
Following numbers describe the size of the insert, the nose radius, the thickness and more. By far and away the most common insert, sold by most distributors, professional and ME.
Edited By Andrew Johnston on 13/01/2013 20:49:33
Chris Trice13/01/2013 21:41:28
1376 forum posts
10 photos
When you say it takes 16mm tools, I assume that's 16mm and with the tip at centre height? Many holders will allow big tools to be clamped in place but not necessarily low enough.
chris j14/01/2013 14:58:19
338 forum posts
17 photos
Posted by Chris Trice on 13/01/2013 21:41:28:
Thanks for the replies.
Yes a 16mm should bring the cutter right on the center line I am told.
I will check it before I go though.
Chris
Terryd14/01/2013 16:31:48
1946 forum posts
179 photos
Hi Chris,
Try this reference for an explanation of both ISO and ANSI designations for defining standard carbide inserts,
As a hobbyist now I must admit that I tend to stick with good HSS tools and prefer it for parting.  If you have low speeds on your machine large diameter parting is no problem, they arise when the diameter becomes small and the tendency is for the tool to submarine and be pulled into the work when using a front mounted tool.
Terry
Edited By Terryd on 14/01/2013 16:35:55
chris j14/01/2013 16:53:47
338 forum posts
17 photos
Posted by Terryd on 14/01/2013 16:31:48:
Hi Chris,
Terry
I must admit that I get better results from HSS but I have always put that down to user error. blush
chris j21/01/2013 21:54:17
338 forum posts
17 photos
I was just looking around the Chronos site at some boring bars and saw some with a through hole coolant system.
Are they any good ?
How do you pump the coolant through ?
Is there a fitting of some kind.
Chris
Edited By chris j on 21/01/2013 22:03:33
Jeff Dayman21/01/2013 22:06:37
2356 forum posts
47 photos
I've seen the through hole bars and drills used on large industrial machines with very high feed rates and 20+HP on the spindles, but I can't imagine a home shop would benefit from them. They are for industrial ops where large metal removal rate is critical (read great big swarf - 10 chips to a pound kind of ops)
The motor on most hobby lathes would almost drive the size of coolant pump you need to properly feed through-hole drills and bars with 80 psi plus coolant.
Just my opinion - save your money for something you really need in your home shop.
JD
chris j21/01/2013 23:49:31
338 forum posts
17 photos
Posted by Jeff Dayman on 21/01/2013 22:06:37:
JD
I thank you for your opinion.
Actually they don't seem incredibly expensive.
I probably should have included a link.
chris j27/01/2013 13:16:52
338 forum posts
17 photos
Posted by JasonB on 13/01/2013 19:57:58:
Parting
Jason
Just reviewing your post.
What did you mean by "through turning" please.
Chris
JasonB27/01/2013 15:49:53
Because of the angle of the cutting edge (100deg+ 5deg clearance) you cannot turn upto a sholder so either have to turn right through to the other side or use the tool to take out most of the waste and then swap for a right hand tool.
Here you can see where I roughed out the crank for my firefly and you have to leave the sholder at an angle. You can take a good cut with these 0.100" if your lathe is upto it.
Firefly138
Then go back and tidy it up.
Firefly141
Edited By JasonB on 27/01/2013 15:56:24
chris j27/01/2013 16:05:33
338 forum posts
17 photos
Posted by JasonB on 27/01/2013 15:49:53:
Firefly138
Firefly141
Brilliant, thanks that makes complete sense.
(I wished you lived around the corner) smiley
