Sean Flood | 16/12/2012 16:27:43 |
![]() 1 forum posts | Hi, I have just completed a new toolpost base from my Chester 220, the old base was pretty flimsy, so I have finally finished a 4 bolt pitkin donut style base. My question... should I attempt to harden it up by heat treating it, it is fairly chunky so I don't expect to bend much, I assume that it may impact some of the dimensions. I have a propane torch but it is 100mm square, it may be difficult to get enough heat into it, another option is to take it to a blacksmith. Thanks in advance for your comments Regards Sean |
Ian S C | 17/12/2012 11:03:27 |
![]() 7468 forum posts 230 photos | Before you think of heat treatment, consider the grade of steel you used, this will govern the type of heat treatment that can be done. Ian S C |
SteveW | 17/12/2012 11:15:48 |
![]() 140 forum posts 11 photos | Big lumps of steel don't benefit much from any heat treatment unless they are subject to direct wear and you do stand a slight chance of it distorting afterwards. So I would leave alone and get on with using the lathe for more exciting things... SteveW |
