Terryd | 21/11/2012 21:14:04 |
![]() 1946 forum posts 179 photos | H Folks, I need to shorten a vertical digital scale - i.e. digital readout bar, Can anyone suggest the best way of cutting it and what must I avoid doing to prevent damage. Thanks in advance Terry |
Ian S C | 22/11/2012 10:39:27 |
![]() 7468 forum posts 230 photos | Terry, I think I would look at using a 1 mm disc in an angle grinder, ideally set up in a jig of somesort, but with care the grinder should be OK hand held. Other than that, a cutting disc in a Dremmel tool. Ian S C |
James B | 22/11/2012 13:10:00 |
![]() 101 forum posts 14 photos | Hi Terry, Similar to Ians comment above, I would use one of these discs in a grinder, these leave a good finish, and as they are only 0.6mm thick (from memory) are not too aggressive. Also, when I have needed to control the cut, I have clamped a piece of scrap onto the part being cut, with the edge on the cutting line - this provides a cutting guide, and I've had good results like this. James |
Ian S C | 22/11/2012 13:21:29 |
![]() 7468 forum posts 230 photos | Another thing, these discs don't seem to generate too much heat, unlike the wider cut off wheels. Ian S C |
Les Jones 1 | 22/11/2012 14:18:39 |
2292 forum posts 159 photos |
Hi James, Les. |
Diane Carney | 22/11/2012 22:15:33 |
419 forum posts 11 photos | Hi Terry D
I picked up your 'report' but it sees you have quite a following! Shall I just leave it here? |
