Myford 254 DRO
ray jones 1 | 16/11/2012 09:01:26 |
54 forum posts 29 photos |
hi, I am in the process of fitting a DRO to Myford 254 lathe. The Crosslide in so not simple. |
KWIL | 16/11/2012 09:38:20 |
3681 forum posts 70 photos | Simple, use a Newall Microsyn scale and head, the scale is only 6mm diameter and you can see under it and get to all the screws! |
Ady1 | 16/11/2012 10:25:36 |
![]() 6137 forum posts 893 photos | I drilled a 4mm hole in my cross slide, tapped for 5mm Fitted a protuding bar from the back of the saddle mounted the caliper on bits of 5mm stud
Has been extremely accurate and reliable
The really important bit is mounting it absolutely straight, this gives a very steady reading If it's not completely straight it suffers from "sticky" bits where the reading jumps
Well worth the effort though, a great mod Edited By Ady1 on 16/11/2012 10:28:44 |
