magpie | 10/11/2012 15:39:06 |
![]() 508 forum posts 98 photos | Hi Folks I hope someone on here can help with a new fault my X1 mill has developed. I have had the mill about 8-9 years and only had one problem in all that time, which was the drive gear had the center ripped out because the key was only 3mm long ! Now when i turn on i have to turn the speed control up fully, and it then takes a second to wake up and move. The speed is also rather erratic. I have checked the motor, brushes OK, comutator looks OK, so not being very clued up on electronics i am now stumped. Could it be the pot, or is it more likley to be the board. I could just about afford a new pot, but if it's the board it will have to wait till funds permit, which could be a while as my state pension is c**p. Cheers Derek. |
maurice bennie | 10/11/2012 16:10:42 |
164 forum posts 1 photos | Hi Derek .Could be the pot needs cleaning, there is a spray which I use that can be found in electronic shops, or radio repair shops .See if you can scroung a squirt from some one . Best of luck Maurice |
magpie | 10/11/2012 16:21:37 |
![]() 508 forum posts 98 photos | Thanks for that Maurice, i have a tin of that stuff i bought from "RS" years ago, i will give it a try. Cheers Derek. |
Ketan Swali | 10/11/2012 17:14:02 |
1481 forum posts 149 photos | Hi Derek, Please checkyour 'My Messages' box. I have sent you a personal message. Ketan at ARC. Edited By Ketan Swali on 10/11/2012 17:29:26 |
Conrad Thompson | 20/05/2018 11:47:01 |
3 forum posts | Hi folks, I need some help. The speed control on my Sieg X1 mill is misbehaving. If I switch to the forward or reverse position with the potentiometer switch in the Off position, the motor idles at a low rpm, with little torque. When the pot is switched on the speed control works as normal with good torque. The power light is not working and I know this is sold as a spare so it may be faulty. Anyone experienced this type of problem? Is it the board or the pot or both? or forward / reverse switch (which is also sold as a spare) Any thoughts and help greatly appreciated. Thanks Conrad |
