michael burton 1 | 05/11/2012 21:23:46 |
126 forum posts 32 photos | hi my mill xj12 need summ fairlky serious repairs the split nut for the table leadscrew thread has gone and ruined my job also the table end plates are so worn on the lead screw theres 2 mm movement in the hand wheel now the problem being i cant get spares for it iv tried so need to make sum bushes and a new split nut but how do you measure the thread of the leadscrew? its not a thread iv come across in the scense off the thread is flat no points to the threads so not sure on that one could some one please explain how i go about this many thanks mike |
John Stevenson | 05/11/2012 22:06:30 |
![]() 5068 forum posts 3 photos | Have you tried Amadeal for spares ? |
michael burton 1 | 05/11/2012 22:14:40 |
126 forum posts 32 photos | hi john yh iv tried its were i got the mill from and normally use him but in this case he dosent do this part
John Stevenson | 05/11/2012 22:19:48 |
![]() 5068 forum posts 3 photos | Try Chester machine tools and ask for spares for the Century mill, same model as the XJ12. Tell them whether it's a metric machine or imperial machine as the nuts are different. |
Les Jones 1 | 05/11/2012 22:23:41 |
2292 forum posts 159 photos |
Hi Mike, Les. |
Nobby | 05/11/2012 22:27:33 |
![]() 587 forum posts 113 photos |
HI michael |
John Stevenson | 05/11/2012 22:52:24 |
![]() 5068 forum posts 3 photos | To further muddy the waters there is not much made nowadays using square threads, too hard to cut on automated machines.
Acme thread if imperial or trapezoidal if metric is the way manufacturing has gone because these can be rolled easily and fast.
Acme has an angle of 14.5 or 29 degree's included. Trapezoidal has an angle of 15 degrees or 30 degrees included.
John S. |
michael burton 1 | 05/11/2012 22:55:00 |
126 forum posts 32 photos | hi les if i have done this correct im not sure i have per rev of my hand wheel graduations it works out to b 1.5mm movement so a lil bit confused but it is a fine thread so could be right the dia is 5/8 or would the dia be a metric size being that its a metric machine it it sure does look like an acme thread |
michael burton 1 | 05/11/2012 22:57:48 |
126 forum posts 32 photos | its measureing 15.78mm od and with a table movement of 1.5mm per rev of hand wheel |
michael burton 1 | 05/11/2012 22:59:36 |
126 forum posts 32 photos | . Edited By michael burton 1 on 05/11/2012 23:03:17 |
Les Jones 1 | 05/11/2012 23:30:49 |
Hi Mike, Les |
michael burton 1 | 05/11/2012 23:37:43 |
126 forum posts 32 photos | hi les i like that link might give that method ago looks simple enough
Paul Barrett | 06/11/2012 06:05:45 |
59 forum posts 16 photos | I have a XJ25 mill from Amadeal (pretty crap mill). I have made new screw nuts for both axis on my mill. The thread is M16 x 1.5mm pitch. The thread form is conventional 60 degree metric form and not flat topped. The Y axis is obviously left hand. I bought the taps from Tracy tools and used lumps of bronze to make the nuts. |
